who makes a webber conversion for 944?
Why use Webers? That's ancient technology and you'll get lower performance than stock even. If you've got extreme mods on your car to the point where the stock fuel-injection system can't be adjusted to compensate, then go with an aftermarket system like Electromotive, Motec, Haltech, Wolfe, SDS, etc. Even the basic SDS system from http://www.sdsefi.com will be light-years ahead of ANY caburetor.
Cruisin'
My idea is to install a couple of double 48mm weber carbs on a normally aspirated 2.5 for autocrossing purposes. I think that flow would be increased giving the motor substantially quicker response coming out of corners.
Anybody done this before?
Here is the sight for what you need...
http://www.weberbbq.com/
This will REALLY make you cook! I may be interested in putting together a group order.
Can't help you much, but I know it's been done on the 924 (not an "S" in this case). I saw a 924 at an SCCA regional at Pocono this summer. At first I though it was a 944, since it had flared fenders. It ended up being a 924 and was running webbers. Apparently it was better than the older FI used on the 924.
-Bob P.
-Bob P.
I left you a private message, but ignore it I found the website the 914 guys were talking about http://www.redlineweber.com/
I think that it could help burn the fuel very well!
Carburetors requires using vacumn, air-flow velocity and the vapor-pressure of gasoline to mix fuel. This can never create as fine a mixture as fuel-injection. The actual burning part is ignition and combustion chamber swirl, things that don't really care about how the fuel actually got into the chamber.
Maintaining the best air-fuel ratio for maximum power is an even more difficult task for a carburetor. It's a mechanical computer and it's not as responsive to altitude and temperature as fuel-injection. Getting an even 12.5:1 air-fuel ratio across all RPM-ranges at all throttle-position openings for maximum power is definitely NOT possible with carbs.
