New Short Shifter for the 944
#31
i like mine, have had it in for about a month.
I bought my car with low kms and its amazing how regular use over 5 yrs has changed the feel of the gear change so I have just bought and am awaiting for delivery of the only944 shift lever.
#32
I installed one on my 87, just love the way it shifts now! DO yourself a
favor, get a mirror to see when the lever is lined up with the divit in the
trans shaft. It's a pain to get things lined up but still it was only a half hour
job..
Steve
job..
Steve
#33
Just an FYI, if you have an early car the install is a PITA compared to a late car. You will have to support your transmission and remove one trans mount to get to the linkage. My stock linkage was so stuck on there it took hours of cursing and wrestling and prying and bleeding knuckles to get it off, BUT it is still so worth it! If you have a late car and the old one ain't so stuck on there it can be a half hour install but if worst case like mine it can take hours haha. And it's kind of a pain to get to being on the top of the transmission and all.
#34
Got Nothin'
I have the short shifter, it looks nice on my workbench. Once I get the N-tune, I will install the shifter. Right now, I can't move the car into position to work on it.
#35
I've been driving my car for a few months now with the new shifter from online944 and I'm telling you it really makes my car feel sweet. crisp shifts and 30% less throws in all axes.
#36
Today I got
My Custom Title
My Custom Title
![](https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash3/1077185_10201746652529482_1486776571_o.jpg)
#37
This sure sounds promising!
Aperently they are 89$ now but with updated design in stainless instead of alu.
The 924S has the late engine and gearbox so should have the late mount?
#38
One more Q:
How important is it to do something about the other rod aprox 15cm going 90 degrees in direction against the rear right wheel on the gearbox?
Don't know what to call it...
What does changing that rod to a uniball type rod mean in feeling?
#39
I have an early 944 and did it with the all four wheels touch the ground and the mount still in place. although space wise it probably helped that my muffler is not that wide. I had a heck of a time with the last nut (shifter position) took me 20 mins to get that thing off.... it at least went on a lot easier then coming off.
#40
http://www.paragon-products.com/Tran...375.045.00.htm
I put my short shift kit in without taking the mount loose. I did it in my garage without a lift, and I don't recall using a jack even though the car is lowered a good deal:
![](http://i280.photobucket.com/albums/kk177/thirdgenbird/black%20friday/DSC00766.jpg)
#41
Today I got
My Custom Title
My Custom Title
Wow yall must be Mr.Fantastics to stretch yourselves into that area without even lifting the car!!!
