944 N/A Brake upgrade
#31
Partially correct. 60-0 is the same..IF you are on the track on that same old straight away you did with your 150hp car, then try it again in your 350hp car, you may not make the turn unless you start stopping much much sooner than before as you will be able to reach a higher speed in that same back straight.
Really, I would think a 1000hp car would be generating a lot more torque than the 100hp car at any identical speed. Isn't that torque at the flywheel going to find its way to the rear wheels when you brake? (Asuming you don't put the clutch in or the shifter in neutral).
#32
I concur that well maintained N/A brakes are just fine. I tracked my car for several years in DE with stainless lines, race pads, slotted rotors up front, stock rotors in the rear, fresh fluid, fresh brake bleeds, and front brake cooling kits <insert shameless plug: which are available for sale>.
What doesn't work so well? Driving home from LRP one night, with race pads nice and cool, towing my tire trailer, some asshat cut out in front of me, with no apparent rush to accelerate. I got on the binders hard and just kept getting closer and closer to his rear bumper. Luckily I managed to avoid a collision, but it was not by much. I kept my nice European halogen high beams on him the whole way back!
J1NX3D (06-02-2021)
#34
good point about the unsprung weight. would appreciate your impressions about the wilwood calipers.
how do you find the braking performance and the front / rear balance. Thanks
#35
#37
Go with something other than the Volvo 4 pots. I have been down this route. Volvo ran double and single brake lines to their calipers. Their early cars all ran double brake lines in the front from the M/C to each front caliper. Those are the non-ABS ones. to use those you'll have to finagle the brake ports a bit. The ABS ones have a single line to the caliper. You can get the right side all day long, but the left front is of unobtanium. Most of those models of Volvo's here on the east coast have been crushed. You'll also have to use a steel brake line adapter from the caliper to the braided hose to clear the spindle. Once you get the caliper on, there is very little room for the braided line to go into the induction port. You have to make a hard right hand bend with the steel line, then you can screw the braided on into that. My AEROQUIP hydraulic guy helped me a BUNCH with this dilemma. Good luck...Wish I had known about the GTO calipers last year. I use stock pads on my '83 with this setup.
#38
The reason that you have to change out the spindle and the bearings is because the N/A early spindle uses cast in tabs to mount the caliper on. The later model cars used a radial mount system to mount the calipers to the spindle. Totally different critters. Unless Rennbay has an adapter for mounting the Wildwoods to an early caliper, you better have deep pockets for this upgrade.HTH some.
