Header and Cat delete, car now sounds like a Honda :(
Old 10-22-2012, 10:54 PM
MooreBoost
MooreBoost's Avatar
i used to have this same setup on my na and LOVED the sound
Old 10-22-2012, 11:00 PM
AlphaOmegaPower
AlphaOmegaPower's Avatar
Originally Posted by dmcampbell
Magnaflow on my '88 TS with a Lindsey 4 inch exhaust, no cat, no center muffler, sounds great.
+951.......for the 2 seconds I heard it before it shut off lmao
Old 10-23-2012, 12:38 AM
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by odurandina
8, 10, 12 cylinders just turns the damn car exotic....
now, obviously, guys run the most hideously obnoxious exhausts with their hot rod corvette engines.
but, it doesn't have to be that way.....
and the ideal sized pipe for a 944 is 2.25".... 2.5" pipe (absolute max) is already very big.
i measured, the ford V10 wont fit
Old 10-23-2012, 12:45 AM
AlphaOmegaPower
lol
Old 10-23-2012, 01:41 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
So the best route is
-remove the cat
-add a SLP resonator
-add a borla xr-1
I have a newish magnaflow cat on right now. Excuse my ignorance but does the resonator replace the cat or is it possible to have cat/resonator/muffler?
Old 10-23-2012, 09:42 AM
bigjoe255
bigjoe255's Avatar
Hey, someone shoe-horned in a mercedes v12 into a fiero kit car, anything can be done!
Old 10-23-2012, 10:24 AM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
all depends on the $$$$$$$..................
Old 10-23-2012, 11:06 AM
Indy Rev
Indy Rev's Avatar
-remove the cat
-add a borla xr-1
The S2 came stock with a Cat/Res/Muffler. If your deleting the cat then replace with a resonator or glass pack.
Old 10-23-2012, 12:37 PM
Cochezz
Cochezz's Avatar
OK sounds like I need to add the resonator.
and a magnaflow or borla at the back.
Damm, I was hoping not to have to redo the whole exhaust.
Anyone know what the rear muffler looks like inside? I want to know how restictive it is.
Old 10-23-2012, 03:01 PM
HICKS
HICKS's Avatar
I had Kyle's old set up,bursch and test pipe, and didn't like the sound. I bought a cat back that had a stock resonator and it sounds much better. Got rid of most the drone, and rasp.
Old 10-23-2012, 03:28 PM
odurandina
Team Owner
odurandina's Avatar
i've experimented with different combinations, and from my own experience i would say that the resonator is important to have
in there whether you are running a cat or not. my preference is to run no cat, but that's mostly because where i live there's no
emmisions or visual inspection after the car reaches 15 years old.
correct.
first, the SLP unit has no restriction.... it's a completely hollow pipe with nothing more than a big bulge in the middle...
http://www.summitracing.com/parts/SL...3919/?rtype=10
the gas passes through smoothly, while the raspy four cylinder engine's sound pulses are effectively cleaned up in the echo chamber.... but you need a larger glasspack muffler than the Hooker Maxflow (top photo) shown, but that's what you're looking at with either the Hooker, Borla or Magnaflow mufflers; straight pipe with very low restriction save for the turbulence that's created via the holes for the sound to go through.
if you go to Magnaflow's website
http://www.magnaflow.com/02product/02muffler.asp
you'll see this 18" X 8"X 5"..... for 2 1/4" pipe
http://www.magnaflow.com/02product/s...=main&id=10414
or 2.5" pipe
http://www.magnaflow.com/02product/s...=main&id=10415
that's about the correct sized glasspack you want to be stuffing back there.
if you want a freakishly nasty sound (but very loud at wot), go with the 14"....
i'm running a 22" !! my exhaust sounds so good at 3000~3400 rpm on the highway,
that i often prefer it to playing the music.
Originally Posted by Ispeed
I got to drive this car last night, so I will give my report on the sound.
It has a big deep sound, and It sounds to me like a tweaked 911 six cylinder sound. It's good stuff.....
Anyways, there it is...
NO CAT for the win.
Old 10-23-2012, 03:41 PM
Dougs951
Dougs951's Avatar
Dumped sounds pretty good on a 3L
Old 10-23-2012, 04:33 PM
Indy Rev
Indy Rev's Avatar
Old 10-23-2012, 08:11 PM
V2Rocket
Rainman
V2Rocket's Avatar
Fit some really narrow tires on the front of the 944, chop the wheel wells out about 5" in either direction, drysump the Ford motor and drop it a bit...chop the firewall back about a foot...no problem
Old 10-23-2012, 10:45 PM
Funn944
Funn944's Avatar
A high flow cat or resonator will help a lot with the raspy sound. I recently put on a Walker Dynomax muffler on my '86 N/A. Already had MSDS headers, high flow cat with 3" pipe from the collector to the muffler. Sounds very nice, not "way to loud" or raspy.
Quick Reply: Header and Cat delete, car now sounds like a Honda :(
