FS 4* Offset Cam Key 8 valve
I have ordered a set of offset cam keys from 928 motor sports. The 928 uses 2, I only need one for my '86 944. The set cost me $43. Will sell the extra one I will get for $21, shipped in the lower 48 states. Josh has had some great results with this mod, check out the write up on the NA-tune thread. PM me if interested.
Michael
Michael
Yep. This can advance or retard timing 4 degrees. They arrived today will post a pic soon or you can take a look on the 928 Motorsports web page.
Never used these offset cams so...
How do you know 4* advance/retard is optimal for the tune?
What if you need 2* or 6*?
Excuse my ignorance but I've only used the adjustable type of cam gear where you can advance in infinite steps until its were you need it. It seems like this offset key is an easy way to maybe get back to stock after a cylinder head resurfacing but not for fine tuning purposes. Please correct me if I'm wrong.
Small Business Partner
+2°
-2°
+4°
-4°
+5° (+cam tooth, -4°key)
-5° (-cam tooth, +4°key)
+7° (+cam tooth, -2°key)
-7° (-cam tooth, +2°key)
Yes, this is not the fine-tune capability that an adjustable cam-gear gives you, but it gives you the majority of the gain for ~1/10th the cost. You just need to test which combination is best, and fortuneally I did that already
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
On a car with a non-milled head, and stock-camshaft, 4° advance is what I suggest, as that is going to bring hp&tq on earlier, and make better use of the camshaft.
See my post here:
https://rennlist.com/forums/9898601-post278.html
Butters, I would expect a 5-6% increase in power at pretty much every RPM. The difference will taper-off in the higher (>5500rpm), but for the majority of the RPMs, it will make a very noticeable difference.
The typical kit comes with a 2° and 4° key, so that you have some adjust-ability. Having either key, you could use it to advance/retard and in-conjunction with changing the cam 1 tooth (a 9° change), it gives you quite a few options:
+2°
-2°
+4°
-4°
Yes, this is not the fine-tune capability that an adjustable cam-gear gives you, but it gives you the majority of the gain for ~1/10th the cost. You just need to test which combination is best, and fortuneally I did that already![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
On a car with a non-milled head, and stock-camshaft, 4° advance is what I suggest, as that is going to bring hp&tq on earlier, and make better use of the camshaft....
+2°
-2°
+4°
-4°
Rainman
Josh, could you explain why there isn't much power gain at higher RPM when retarding the cam? One would think, that shifting the powerband up in RPM, more power would be produced as HP is a function of RPM...
Spencer,
I'll answer as I explained it a little to Josh when on the dyno.
When you build torque earlier in the rpms it compounds apon itself to a degree and thus adds horsepower too.
When shifting the torque curve to the right ,there isn't enough RPM or airflow to take advantage.
My thoughts on it
My thoughts on it
Spencer,
My thoughts on it
My thoughts on it
Changing cam-phase does not affect total duration or lift, so while phasing the cam shifts the power around, it is still ultimately limited by the actual cam-profile.
Here is an overlay, the only difference in the two pulls is cam-timing (retarded 4° vs advanced 4°, other mods were my NA-Tune & 2.5" exhaust). The blue is the retarded cam, the green is the advanced cam - everything else is the same. Which curve would you want?
Rainman
Agreed. Additionally, even though retarding the cam did help keep top-end power up (though it was still less peak hp than advancing it), the stock cam (and maybe intake manifold?) is simply not aggressive enough to make use of the upper-RPMs.
Here is an overlay, the only difference in the two pulls is cam-timing (retarded 4° vs advanced 4°). The blue is the retarded cam, the green is the advanced cam - everything else is the same. Which curve would you want?
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
