FS 4* Offset Cam Key 8 valve
#31
Small Business Partner
http://www.roguetuning.com/944_maf_kit_na-tune%C2%A9
Do you have the ignition dwell adjustment for the HVC-II coil? What about the added capacitor on the DME board?
#32
Rainman
i dont know if you saw it in my thread, but my stock exhaust car with 2* advance made about the same numbers as your 951 muffler/4* NA tune run. i think it's most likely due to my engine being "younger" (lower miles) than yours might be? it's pretty much flat from 5300-5700rpm at ~133rwhp.
pushing it out more is just to see if theres anything more to be gained beyond the +4 advance you tested.
comparison between larger maf housing + injectors vs the same with +2 cam advance...
#33
#34
#35
#36
This link below doesn't work any longer, here is link to instructions:
https://rennlist.com/forums/924-931-...t-cam-key.html
Hopefully will get a chance to FINALLY get this done this weekend. For anyone needing instructions on how to swap the cam key out:
http://www.benms.com/944camseals.html
Michael
Michael
