Planning a couple of projects, need some advice (content heavy)
Old 10-12-2012, 04:57 PM
  #31
Dougs951
Dougs951's Avatar
trans or clutch?
Old 10-12-2012, 06:53 PM
  #32
bordin34
bordin34's Avatar
Luckily the trans is very easy to replace. You can do it in about 4 hours. The hardest part is cleaning out the bolt heads and removing the cv bolts.
Old 10-13-2012, 09:41 PM
  #33
lovemyp-car
lovemyp-car's Avatar
this is the fourth trans I've had in this car...i can do it in 4 hours in my driveway, from jacking the car up to dropping it back to the ground with the new trans installed. It's almost definitely the trans, we'll see for sure when i pull it and drain it, i'm hoping it's not a combination of clutch and trans issues
Old 10-13-2012, 10:04 PM
  #34
MooreBoost
MooreBoost's Avatar
put a turbo trans back in
Old 10-14-2012, 05:48 AM
  #35
mikey_audiogeek
mikey_audiogeek's Avatar
Originally Posted by lovemyp-car
Doug...eww...gross. I'd love to steal the motor out of it but...bleck!
Mike, thanks for the help man, definitely some good information!
No worries! I like a loose setup as well, on the street. I haven't tried the KW's, would like to though. The helper springs on the KW's aren't the reason for the smooth ride, they do nothing unless the wheel is off (or nearly off) the ground.
Cheers,
Mike
Old 10-19-2012, 08:36 PM
  #36
lovemyp-car
this was a turbo trans...an 87 with lower miles in fantastic shape...shifted great, no synchro problems, no gear problems. It was the best trans I've had in this car. BANG.
I'm thinking I'm going to drop some serious coin on an 86 cooler and LSD model, maybe keeping the trans temps a little lower and having a stronger, non-open diff will help
Quick Reply: Planning a couple of projects, need some advice (content heavy)
