CNC or waterjet vendor to make custom dash panel
Old 10-09-2012, 11:32 AM
LuigiVampa
WRONGLY ACCUSED!
LuigiVampa's Avatar
Received 4,320 Likes on 1,902 Posts
Default CNC or waterjet vendor to make custom dash panel
I pulled out my transmission tunnel over the weekend and want to replace the panel where you normally have the radio with a square of aluminum or steel and have someone cut three holes for gauges as well as some smaller holes to mount electrical switch, starter button, etc.
Anyone know a vendor who does this sort of work without breaking the bank?
Thanks!
Old 10-09-2012, 11:54 AM
will951
will951's Avatar
Bring it to someone with a plasma cutter.
CNC or Water jet will cost a fortune due to programming costs.
Old 10-09-2012, 11:56 AM
LuigiVampa
WRONGLY ACCUSED!
LuigiVampa's Avatar
True - so just to clarify, I need someone to put some holes in metal. I don't mind how they do it so long the lines are straight and accurate.
CNC, water jet, plasma cutter, etc. - anyone have a vendor?
Old 10-09-2012, 12:02 PM
will951
will951's Avatar
What do you need done Todd? Remember......I own a machine shop.....
Old 10-09-2012, 12:20 PM
LuigiVampa
WRONGLY ACCUSED!
LuigiVampa's Avatar
Will - sent you a PM with what I am looking for. Forgot you had a machine shop. Thanks!
Old 10-16-2012, 12:29 PM
Slayer952
Slayer952's Avatar
Made my own if you want a template to work from
Old 10-16-2012, 04:14 PM
333pg333
333pg333's Avatar
There's a company that makes these with whatever you want, inc laser etched writing. You design it and they make it. Seemed pretty good. I can't remember who they are but ask around. Someone will know. Chris White pointed them out in the past.
Old 10-16-2012, 04:33 PM
catamax944
catamax944's Avatar
rennbay also has them and they are cheap http://www.rennbay.com/944-gauge-plate-hole-p-181.html
Old 10-16-2012, 04:37 PM
linzman
linzman's Avatar
Has anyone seen one that covers up the radio part also, ie a double din sized plate, preferably with 3 gauge holes?
Old 10-17-2012, 08:28 AM
will951
will951's Avatar
This is what I will be making for Todd (LuigiVampa)
Old 10-17-2012, 09:19 AM
ilikemy944
Going with the pack
is quite monotonous.
ilikemy944's Avatar
I have seen some from here and they look good, not too expensive either.
http://www.gaugeplates.com/
Old 10-17-2012, 10:54 AM
EJZero1
EJZero1's Avatar
www.frontpanelexpress.com
Mine took about two weeks. Excellent customer service, and you can track the progress of your panel on their website.
$34 for mine.
Forgive cell phone pic. Looks far better in person.
Quick Reply: CNC or waterjet vendor to make custom dash panel
