Friend just bought 1987 924s
I need to know some info on the motor and info in general information. It sat for 9-years has 44k on the car. He has given me a motor code of 44105250 GR if this makes sense. Is this an interference motor or the same motor as the 944?
Thanks, that was what I thought 1/2 the motor of the 928! Wonder if the porken timing tool will work for the cam timing. What is this car worth he paid 1,200 but paint is faded dash cracked but the rest of the interior is like new. I am suggesting full maintenance, tires possible caliper rebuild, fuel lines belt pump etc before he even starts it.
Proprietoristicly Refined
I may be mistaken if you tell me the car was kept covered in a climate controlled garage..
Even as a "project" the car has no value.
Complete info:
www.Clarks-Garage.com
John
One owner x hwy patrol he brought it from calif still has the old plates on it. He had 3 heart attacks and stopped driving it. I have rebuilt 7 928's some in the same condition so I know what he is in for.
Update after 9-years sittinf
Finally got car running but have a couple of issues.
Hard to start cold when warm idle is erratic. Fan runs constantly Ned to disconnect the battery to have it shut off.
I need to check the Temp-II sensor and ACV valve any other area to check?
I will smoke it and verify fuel pressure the balance belt whines a lot maybe too tight.
Looking for a pin out of the DCM to test inputs and any feedback to help get this running correctly.
All new fuel components and rebuilt Injectors, new electrical components and front end of motor.
See post #2
http://forums.pelicanparts.com/porsc...when-cold.html
And from Clarks:
http://www.clarks-garage.com/shop-manual/ts-01.htm
GL
J_AZ
And from Clarks:
GL
J_AZ
good luck with your project.
I am about to buy an 87 944S, blk/blk. add a 'remora' to run with my shark.
very good cosmetically, 107K miles, EXC leather interior. guy is second owner, car developed some driveability issues and then stopped running. no sound from fuel pump. had developed arthritis and not comfortable driving, so decided to sell.
so after refreshing pretty much everything on my 928, needed another project.
Nice to see people still attempting to restore these.
I believe I have gotten a LOT more pleasure refreshing/driving my old porsches that if I just went out and bought a new one.
did I say no car payments? now if I win the lottery .....
forgot to post the pics from the listing. hope to pick it up this weekend.
Update 1/29/2013
We have it running, I found out owner washed the tank with water and it took a while to get rid of the moisture. That said, the idle is rough, car starts up fine and runs good. I have replaced all the related fuel components and had the injectors rebuilt.
Could this be a balance shaft adjustment, we followed the instructions on Clark's garage and believe we got the gears in correctly and set up as described. Can anyone shed any light on this?
Also looking for a headlamp motor and any help on the oil pressure connections going into the pod.Low oil pressure lLamp is on no pressure on the gauge new sender tested for low pressure, it is good.
