auto to manual swap, some questions
I have access to an '87 924s and an '87 944, both 5 speed cars. I have an automatic '88 and was considering doing a transmission swap. Would it be worth doing or should I wait until the auto trans dies, I mean needs replacing.
Can someone tell me which car would be better for the swap, if any?
What parts would I need to remove from the donor car?
Will the wiring be a simple plug and play process or is it more in depth?
I used the search but couldn't find clear answers.
Thanks for the help.
Proprietoristicly Refined
Most of the information I have suggests using a rubber center clutch disc to make the shifting smoother.
Hard to find a rubber center NOS or in decent condition.
Here are a couple of links I bookmarked:
Sponsor 944Online has information and call if you need help.
http://www.944online.com/cgi-bin/for...num=1297199732
RL info:
https://rennlist.com/forums/924-931-...yle-setup.html
https://rennlist.com/forums/924-931-...n-fitment.html
GL
John
RL info:
GL
John
