The reliability challenge question!
#76
#77
#78
Any car can be made reliable with the proper maintenance and cost required. But when "budgets" and "shortcuts" are used, compromise comes into the picture which hinders overall reliability due to neglect or lack of funds.
#79
I have one: the ignition switch. It's made from a brittle plastic which is prone to crack. It's just a poor overall design - I have one in front of me right now and there's a reason it's $4.50... I would rather pay $50 and have it last 20 years. One could argue that it's a VW part, and you would be right, but Porsche carried it in the 944 through 85.5. I have no reliability data (or tales from 944 friends) on the late 944 ignition switch.
Also... DME relay anyone?
#80
Reliability is not subjective at all, it is quantitative. A person’s opinion regarding reliability is subjective. Unfortunately, my opinion regarding Porsche right now, would be very bias indeed, as I made an impulse purchase for what turned out to be a very poorly maintained and severely abused 951.
Because of that I will keep my opinions regarding Christine to myself. However, if I end up dead and she is anywhere nearby, Steven King fans will know what really happened, even if it was made to look like an accident. :-)
In all seriousness, I think it is safe to say that the Porsche 944 Turbo was the most sophisticated mass-production car in the world back in 1986. Cheating on the numbers here a little bit, but 220 hp out of a 2.4 liter motor was a phenomenal achievement. Problem is, sophistication and age do not make good bunk mates. Hence the arguments regarding reliability.
For me the real issue here is ease of maintenance or perhaps more to the point, lack thereof. When I wrench on Christine, all I can think about is how little attention was given to simplifying maintenance. Then when I compare her to my ‘75 VW Bus, I just get depressed. Let’s see, removing the entire engine on the side of the road using only basic hand tools in less than 30 minutes; or 24 hours shop time to replace a simple clutch. Think that’s an unfair comparison? Perhaps, but keep in mind which car company designed both drive trains?
If I had one wish for my car, it would be that she was less time consuming to work on. As it stands, Christine is a greedy little you know what, and she demands my full attention and requires constant praise and adoration, offering me little in return except for the occasional short lived ride.
#81
Rainman
I make the
face whenever I see/hear people say things to the extent of "well it must be perfect and ideal that way, it is a Porsche after all!"
As far as reliability is concerned, MAINTENANCE is the key of course.
Let me put some numbers here for posterity, of what a nearly 30-year old engine that's been taken care of (but not driven lightly) can do with a newer catalyst...burns cleaner than any other car in my family, despite being the oldest by over a decade.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#83
I make the
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
#84
I purchased my 87NA when I was 16 my uncle helped me out. It had 2 previous owner, I'm the 3rd going on 7 years of owner ship.
The car had sat for roughly 6-8 years before I touched it or anything so like most it was in good condition body wise no rust straight no dings nothing but had electrical problem because 6-8 yr sitting attracts critters to crash and make a party anywhere.
Changed everything new fuse box relays wiring harnesses everything got went threw the 1st yr then normal valve cover head pump belts and to this day it's a champ runs drives great no complains mind you even in the snow ((not a lot )) I still drive it and it's all good
A well maintained car doesn't matter the brand will go on forever specially if you don't cheap out on parts.... I know acouple guys that the car needs something fixed no they keep running it till more breaks down and the bill ends up being a lot ((mind you it ain't a Porsche)) just because they ignored the thigs that needed to get fixed.
My parents bought a Toyota sienna fully loaded back in 98 and till this day my mom uses it to go to work 215,099 miles same engine I'm just saying DOESN'T MATTER THE BRAND YOU TREAT A CAR WELL AND FIX THIGS WHEN THEY NEED TO GET FIX THE CAR WILL KEEP ON DRIVING.....
The reason why cars become parts cars is because they ignored what needed to get fixed until they saw it was too much so they decide to part it out
When I run into other 944/951/924/928 doesn't matter which on the road it puts a smile because I'm like yes another person loving a true car and trying to keep it off the scrap yards
#89
first trans was probably damaged as the rubber clutch disk failed - I heard a "buzz" from the rear under heavy accel for about 2 weeks, then on the way home it locked up intermittently, ultimately ripping the rubber disk out of the center of the clutch - a tooth had broken off the pinion gear. So, I got a rebuilt and put it in (along with a new clutch) - the rebuilt was not properly assembled, so after maybe 50K miles the side plate came off destroying the case. The final trans was a factory new, in box, trans - it has been good up to now. I still have original axles in rear, by the way. I changed ball joints in the front but they weren't very badly worn, it has had two starters, one broken in half by my brother driving off the curb, and two steering racks but those are minor. And, I did a valve job when I made a very stupid mistake on my first timing belt change. Oh, and I replaced the cat just last month when it failed smog for the first time.
