Need wheel offset experts
i am looking at a set of aftermarket wheels and am concerned about the fitment of the fronts, they come in a 17x8 and 17x7.5 with an offset of 45+. ideally i would like 17x8's all around to allow me to switch fronts with rears of the same side if i ever need to (asymmetric tread), plus more grip to take advantage of the front brakes. however, i am thinking the 17x8's will rub the front fender and the 17x7.5 will just squeeze inside without problems. this is for a late offset car.
option 1:
fronts 17x8 et45 245/40 r17
rear 17x8 et45 245/40 r17
option 2:
fronts 17x7.5 et45 225/45r17
rear 17x8 et45 245/40r17
option 1:
option 2:
The fronts 17x8 et45 will fit too btw, however you might wanna keep the tires at 225/40 to be on the safe side. Oh, and you didn't mention if your fenders are rolled or not... S' are rolled from factory so I forgot about that
its a 944 S2. suppose i could just get two 17x8's and try'em on, if they rub then just put them on the rear and get the 17x7.5's....
these are the wheels http://www.tsw.com/alloy_wheels_nurburgring.php they weigh in at 17lbs, forged, and cost about $1000 for the set.
I have 16x8 et11 in front on my 88 S' if that's any consolation. They didn't rub with 225/55 tires but were very very close. I changed to a smaller tire, but considering my offset was much lower you shouldn't have any problems with the rim itself. I would only be worried about tire size. That said, My fenders are rolled and I do have bilstein coilovers with camber plates. The rims you want don't have much (if any) of a lip so I think you should go for it
If you get these, I'll be intersted to see pics and hear what size(s) you went with, if there were any issues, etc.
these so far are the best forged wheels i have found that look good and are at a good price . i plan on trying out the two 17x8's sometime in the next month or so, but i will post some pics when i do.
Today I got
My Custom Title
My Custom Title
Those 8" 45 offset wheels will stick out 1.97cm more than stock 7" 52 offset wheels, if you want to know the literal answer. Up to you if 2 cm is too much extra as far as possible rubbing goes.
Today I got
My Custom Title
My Custom Title
Those wheels look very nice
It bugs the crap outta me when companies have improper grammar in their web pages...
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.rimsntires.com/specs.jsp
just need to get some solid measurements from the hub to the fender.
