FS Sparco seat mount, metalmaster pads, wheel paint, spare tire, ISV
Used Sparco aluminum side mounts and early 944 drivers side seat slider rails. Came off a Sparco Evo seat I purchased. Previous owner drilled the side mounts to suit the sliders to be straight bolt on to any early or late 944 if used with a Sparco Evo seat. $60 plus shipping to CONUS only.
Used set of front and rear Axxis / PBR Metal Master brake pads to suit a 944 turbo (8 pads total). Code on pad is DB 440 BMXBG. Barely used. Measure >12mm pad thickness. The Pagid RS 4-2 pads I replaced these with came new with 12mm of thickness so I am calling these 99% remaining. $35 plus shipping CONUS only. SOLD
New can of Einszett Silber spray wheel paint and new can of Wurth clear Lacquer. This is the perfect match for the factory porsche wheel color. $20 plus shipping for both cans. CONUS only.
944 steel spare tire. Came off an 87 944. In excellent condition. No rust. Tire itself has never been used on the road (moulding nubs still intact). $20 plus shipping CONUS. SOLD
Low mileage idle control valve / idle stabilizer valve ( ICV / ISV ). Was fitted 15,000 miles ago and no longer needed. Still have the original box it came with when first fitted. Works as new with no leaks. $40 plus shipping CONUS only.
