Issue with caster blocks and chassis
Here's my situation:
I was getting a bad clunk sound from my front right suspension, and when I dug into it, I discovered that the outboard caster block bolt was missing and the inboard was only finger tight.
I removed the inboard bolt to take it to the hardware store and find a match. When I got back home, I was able to secure the outboard side with the new bolt, but I am unable to get the inboard bolt (the one that was originally there) to thread on. It is as if the female threads broke off.
Is this a common issue? And is there anyway to access the rear of the mounting surface?
TIA
Brad
TIA
Brad
Here is a time-sert if you have something to thread into: http://www.timesert.com/
Here is a nut-cert if you do not: http://www.mcmaster.com/#nut-certs/=hy84qs
video on nut certs:
video on nut certs:
OP If your'e lucky you can stick a magnet in there and maybe grab the nut to position it, that's what I did anyway
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
don't buy 944 caster blocks. get the ones for a 968. stiffer and longer lasting.
far and away the better choice.
Zims has the best prices on these.
