944 clutch kit
944 clutch kit
Buying a clutch for my 1984 Porsche 944. Wondering what you guys thought is the best clutch kit out there. My budget is about 800$. Thanks for any responses.
Joe
84 944 Daily driver
Joe
84 944 Daily driver
http://www.google.com/products/catal...MAI#ps-sellers
saches is great, its sprung center rather than the rubber that deteriorates, i just put the clutch kit in my car and i abuse it on a daily basis and it holds up great!
Rainman
You can save a metric boatload of money by having your clutch disc re-lined rather than replaced, assuming it is the spring-style already.
New clutch disc, spring style - $400. Relined disc (good as new) - under $100.
Depending on mileage and driving styles, the flywheel may be able to be resurfaced. Then you'd just need a new pressure plate/TOB (about $340) and good to go.
when i did mine i got my flywheel resurfaced, it cost $43 so i figured its cheap insurance. it would suck to have to chatter, or hot spots because you didn't want to spend $43
@V2Rocket
I don't have a spring center clutch disc because I believe I still have the stock clutch in the car. I also realize the flywheel will have to be replaced. I am wanting to know the best brand of clutch to put in it.
I have looked up a centerforce dual friction pressure place and disc and that is for 720$ on summit.com
I have seen a few more options but that is what I'm comparing them too.
When did you buy your 944? I bought mine about a year ago and it didn't have any records with it (don't worry, I checked it out well and got it CRAZY cheap). I pulled the engine recently and sure enough, it had a spring center clutch disc on it. I would suggest pulling the old one out before writing it off - you never know!
Spencer is right, we sent ours (clutch, Pressure plate & flywheel) in to Southbend and got it upgraded to stage 2. With shipping, beadblasting and the machine work to the flywheel and pressure plate, the bill was $350. We could have gone with the old release bearing but it was a little loose so then needed a release bearing, pilot bearing, guide tube and PP bolts for another $250. Here's a pic... Bruce
At this point it is either Exedy or centerforce as a kit replacement. I am looking for something a little stronger than a sachs unless somebody thinks a centerforce is overkill.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
For an every day driver the Centerforce Clutch is over kill. A Sachs Clutch is more than enough for a DD. Remember a stiff clutch creates more flex at the fire wall anchor point. A stiffer clutch is used on a Track car where there is not that much shifting done and better holding grip at higher speeds. An example for complete kit needed for the replacement of your clutch.
http://www.944online.com/cgi-bin/ASI...41+clutch-9441
Cheers,
Larry
Cheers,
Larry
if this is for a street car, buy the cheapest clutch you can find. you don't make enough power to tear one up, unless you're a complete dumbass and drive with your foot halfway down on the clutch pedal.
I put a USED clutch and PP in my '87S, took 420 grit to the flywheel, bolted it all back up and it's fine. thinking you need a "stronger" clutch is a waste of money. your friction surface didn't wear out--the center broke. my clutch had nearly 130k on it and could have gone 20k more if the rubber didn't shatter.
