Introduced water to my 951 engine bay... PLEASE HELP
Hi all. Recently Ive acquired my first Porsche, specifically an 86 944 turbo. Unfortunately I went about removing some of the dust from the engine bay with a pressure washer. Although I was very **** about what areas got attention, I somehow manage to dislodge something relatively important.
Once I started the vehicle after washing the bay, ran smoothly for a few minutes then shut off without a sputter. I then went to restart the engine and it starts on the first attempt WITHOUT ISSUE, but if given any gas, will sputter until it shuts off.
After getting her back home to hunt a little deeper, the idle became rough as if there was a pretty sever vacuum leak. I then went about removing the fuel rail and intake manifold in order to hunt down the issue, to find nothing out of place.
After re-installing the plenum/fuel rail the car will no longer hold an idle AT ALL. The engine immediately shuts down after cranking, but it does fire up. Any help with further diagnostics would be highly appreciated.
BTW the car is running the Quad-M 85mm MAF which could be the culprit to my issue But I have yet to test.
yea, Ive checked all the obvious possibilities. It has to be something which resulted from the water or pressurized water because prior to this I have yet to have ANY problems what so ever. It hasnt run since (been about a week)
I do believe that could possibly be the reason for the stalling on accell but now I must determine the issue with the instant shut off after the engine fires. I would call it a fuel issue from the way it fires then just dies. DME relay is good.
1 Post
Water in engine bay..bad idea. All you can do now is unplug every connector you can find, and make sure it is clean and dry. Everything may look ok..but something got wet. Open the hood and let it dry out. Yes there is a chance something may have "moved" due to the pressure washer spray hitting it, but most of the time, it is "simply" a matter of an electronic part getting wet, and hopefully not fried...
Goodluck.
Goodluck.
Goodluck.
Goodluck.
Pressure Washer
Pressure Washers are Bad for cars, especially around engines, trim, etc. maybe not so bad to clean undercarriage. My guess is the harness connection to the AFM got wet. Remove and clean. Good point on vacumn lines also.
I've pressure washed engines for decades without issues.
????? WTF????? These cars are known for NOT rusting except n rare cases
