help me analyze my spark plugs! [BIG PIC]
After owning my 951 for a little over a year I am changing the plugs, leads, distributor (cap & rotor) for the first time. It's been idling rough for the first few seconds on startup, and occasionally hesitating during acceleration around 2K rpm. I spotted some arcing from the plug leads, and indeed the insulation on all the old leads is looking pretty tired.
I haven't removed that many plugs, but I don't remember ever seeing this kind of variation in the colour of the insulators before. Do these plugs tell you anything interesting? I don't find the guides on Clark's on the Haynes manual all that useful as the pics in Haynes are black and white and the descriptions are vague.
These are ordered - cylinders 1-4, left to right. 4 is significantly darker than the others, with 2 being a lot lighter. The electrodes don't vary so much, but number 4 does seem a bit darker coloured than the others.
Also, all 4 were gapped around 1mm - which is more than the new ones (which were around 0.7 - 0.8 out of the box, as recommended by Clark's Garage)
![](http://i1189.photobucket.com/albums/z424/an_broc_si/4_plugs.jpg)
Have you done a run after you changed the wires etc?
I see them as
1 slightly less than beautiful
2 beautiful
3 ok
4 either a bit rich or burning some oil
Nothing serious by the looks of them. Definitely change the gap back to 0.7mm. 1mm is too big and may have contributed to your rough running. Definitely change your plug wires. I just went through this a couple of weeks ago.
2 beautiful
3 ok
Do you have pictures from the other side of the plug so you can see the color change on the strap.
check the injectors for equal flow
Hey,
i own a 944S2 cabriolet and my plugs look the same because they become loose after est.5000Km. Number two is ideal, the other 3 are not torqued within spec. i guess.When you remove them from the head check for oil residue. If you find oil arround and your plugs look like Nr.4 torque them down to spec.
The engine is full alumnium so something arround 30Nm will be fine.
Get the right plugs TURBO= Bosch WR7 DC and replace them every 15000miles !
