No Spark 83 944
Well let's see if any of you guys can help me out here. I have no spark on my car, and no power going to the coil. Which would lead me to believe that the ignition module is faulty or perhaps a DME relay..? But if the DME relay went out I don't think id be getting any fuel either if I read right. I did my searching and found only info about ignition modules on the S and S2 models.
Where is the ignition module located and does anyone know resistance values to help me diagnose? I have checked Clark's garage and pelican as well.
The 9 pin connector above the brake booster has power at the thick green wire (which I believe is the coil wire) with the key on. Also cleaned some corrosion and fixed a wire at the 2-pin connector an still no power to coil.
My reference sensor connector is all cracked but has been for a while, I have the pins in as far as I can get them and even moving them around while cranking doesn't help.
I read that the DME relay has solved no spark problems but as said above it doesn't?
Arrrgh!
Arrrgh!
Well with my meter I have power at the black wire (+) at the coil only when I ground to something other than the neg side of the coil.
I tried jumping the negative side of the coil and nothing. Also tested the coil by grounding a spark plug while it's in the coil wire and theirs no spark no matter how I set it up. Also tried an over the shelf coil lying around in the garage and still nothing.
I'm going to order reference sensors because it needs done regardless
The green wire is not the negative side of the coil. It is the trigger. It gets grounded by the DME to generate a spark. Did you follow Clark's procedure for testing the coil?
I had a problem last year where the black wire would measure 12V but would not generate a spark when grounding the other side of the coil. It turned out that the black wire was broken somewhere and was just barely making contact. It wasn't strong enough to generate a spark. I ran a jumper wire from the black wire directly to the + battery and it was fine. I doubt that's your problem since that is such a whacky failure.
After verifying that your coil is working I would be looking at your reference connectors since you mentioned that they were all damaged.
