8v 2.5 NA MAF - Will It Ever Happen
Old 04-25-2012, 02:27 AM
Dimi 944
Dimi 944's Avatar
Originally Posted by Rogue_Ant
Gains, I will quantify on the dyno - but typically on a turbo car we see nearly 10% increase across the board from just going to MAF (no other changes). I expect to see something similar for the NA.
Cost, I will put up once I get closer to release.
Here are a couple quick pics:
It looks great but is there going to be another/optional housing for the MAF sensor (i.e. a complete cylinder) for other air intake set ups besides the stock air box?
Dimi 944 is offline
Old 04-25-2012, 02:28 AM
Corey944
Corey944's Avatar
Interested, as well
Corey944 is offline
Old 04-25-2012, 02:49 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by Cone_eater
oh, now I understand. I'm sorry. I was entirely confused, I apologize for my ignorance.
Ha no problem
Originally Posted by froby944
Shoot me an alert when your ready to sell them. I'm in.
I'll make an announcement when its ready.
Originally Posted by GTSilver944
Sweet. I'll be buying one.
Are you still in CO?
Originally Posted by robstah
Josh, the last place I would look for MAF sensors would be from Germany. Go look through the parts bin of Ford/GM/Hyundai/Kia. Most of those MAFs should be cheap, reliable, and can handle some power with the right housing. I know of quite a few tuners that have used Ford MAFs that seem to work wonders on FI based applications.
Rob, thanks for the heads-up. I've already picked a sensor. I was just trying to elaborate on some of the difficulties associated with doing a proper MAF setup for the 944NA.
Not at first. To keep costs down, there will be the one style (at leas at first). You can always put on a filter adapter to the pipe, just like you could with the stock AFM...
Rogue_Ant is offline
Old 04-25-2012, 09:16 AM
MAGK944
MAGK944's Avatar
+1 a cylinder option would be good. I'm sure a lot of us have removed that airbox long ago and going from cylinder to adapter to cylinder on this would be a step backwards.
How about issuing a cylinder option first with an adapter for the airbox, cover all bases? Seems like it would be easier but I'm no expert
MAGK944 is offline
Old 04-25-2012, 09:59 AM
ZR8ED
ZR8ED's Avatar
I would be in for something that is plug and play. Is this going to require a modded chip? I already have the Wilk chip.
I have not eliminated the stock airbox, so the airbox fitting works for me. I've gone as far as I am comfortable with modding my afm. (I removed almost half a shot glass worth of aluminum from the inside when I got creative with my diegrinder, but I still have the same flapper door just like everyone else)
ZR8ED is offline
Old 04-25-2012, 10:58 AM
FabilichuS
FabilichuS's Avatar
Im getting one for sure !
FabilichuS is offline
Old 04-25-2012, 11:17 AM
Dimitri_944
Dimitri_944's Avatar
I want one
Dimitri_944 is offline
Old 04-25-2012, 11:21 AM
Dimitri_944
I want one!
Old 04-25-2012, 12:37 PM
GTSilver944
GTSilver944's Avatar
Nope, moved to NY for grad school.
GTSilver944 is offline
Old 04-26-2012, 12:18 AM
blown 944
blown 944's Avatar
It will be plug and play, and will replace your current chip. It uses proper maf coding rather than emulation so in other words, it is just like a factory maf car.
Just answering for Joshua.
blown 944 is offline
Old 04-26-2012, 01:22 AM
Rogue_Ant
Rogue_Ant's Avatar
Hrm, I haven't considered this... The problem, is that there isn't much room to play with (MAF and adapter + coupler in the same space). Additionally, the NA air-box, while it isn't pretty, draws in cold-air, and has a large filter area... I do not believe there is much (if any gains) from eliminating it. AND any gains would require a proper cold-air induction. If you have a simple cone filter sucking in engine bay heat, then most likely there is a reduction in power compared to the stock box.
Yep, Sid is correct (thanks!).
Originally Posted by Dimitri_944
I want one
I want one!
Does this mean you want two
Ah, cool - miss Colorado yet
Old 04-26-2012, 03:52 AM
jfmitchell44
jfmitchell44's Avatar
i'd like one, will you ship to england?
jfmitchell44 is offline
Old 04-26-2012, 09:49 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,182 Likes on 1,232 Posts
Any love planned for the 16V's?
hacker-pschorr is offline
Old 04-26-2012, 04:01 PM
Giantviper
Giantviper's Avatar
I would definitly be interested depening on performance gains and cost.
Giantviper is offline
Old 04-26-2012, 08:15 PM
Rogue_Ant
Rogue_Ant's Avatar
Yep, no problem.
Yes, they are on the list - expecting sometime this summer.
Obviously the gains are not going to be like a turbo car. But the price is going to be significantly less than the turbo kit...
Quick Reply: 8v 2.5 NA MAF - Will It Ever Happen
