8v 2.5 NA MAF - Will It Ever Happen
Old 04-25-2012, 12:04 AM
MAGK944
MAGK944's Avatar
Default 8v 2.5 NA MAF - Will It Ever Happen
So we've had the Miller MAF that did not get finished, the n-tune which seems promising but still waiting and a few ghetto MAF's that didn't quite succeed in a complete solution.
How hard can it be? Is it that vendors think na development just isn't worth their time? I know we're a cheap crowd but there must be some money to be made.
Let's see where we all are in this. If you would SERIOUSLY be willing to spend around $300 for a tested NA MAF solution that is reliable and provides reasonable performance gains add your name here. Maybe if we get a bunch of names a vendor will step up. I'll take two for starters.
MAGK944 is offline
Old 04-25-2012, 12:12 AM
blown 944
blown 944's Avatar
yes it will for sure. I know Josh is very close to it. There are so many projects he is working on right now that will be well recieved. I think he could relese it right now if not for trying to implement some other things at the same time.
Maybe if there is enough interest shown he'll just release it as is. I know it works, because I've used it.
blown 944 is offline
Old 04-25-2012, 12:23 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
I'd be in.
Butters944 is offline
Old 04-25-2012, 12:30 AM
pops 83 944
pops 83 944's Avatar
I would love to have one!
pops 83 944 is offline
Old 04-25-2012, 12:34 AM
Cone_eater
Cone_eater's Avatar
I'm in!
Cone_eater is offline
Old 04-25-2012, 12:52 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Sid is correct - the 944NA kit is all but done.
But MAGK944, you did highlight some of the issues: tested. I could release it now, but it would not be as tested as I would like... I am simply not willing to sell something that I'm not 100% confident with.
The second issue is cost... I sympathies, as I definitely wouldn't want to spend much for the limited gains an NA will see (compared to the turbo). But this doesn't take away the fact that quality components cost more. I have looked at less expensive MAF sensors (typically Bosch based) - but their reliability is crap. Spend just a little bit of time searching a VW/Audi forum about MAF failures. I am not willing to sell hardware that has such a shoddy track-record.
That said, I will have the kit done, and ready for sale next month.
Rogue_Ant is offline
Old 04-25-2012, 12:56 AM
Cone_eater
Cone_eater's Avatar
pics?
cost?
gains?
Old 04-25-2012, 01:16 AM
Rogue_Ant
Rogue_Ant's Avatar
Gains, I will quantify on the dyno - but typically on a turbo car we see nearly 10% increase across the board from just going to MAF (no other changes). I expect to see something similar for the NA.
Cost, I will put up once I get closer to release.
Here are a couple quick pics:
Old 04-25-2012, 01:32 AM
Cone_eater
Cone_eater's Avatar
I am slightly confused. Does this bolt to the stock set up or replace it?
Old 04-25-2012, 01:36 AM
Rogue_Ant
Rogue_Ant's Avatar
It replaces the AFM, but otherwise is a bolt-on kit.
Old 04-25-2012, 01:40 AM
Cone_eater
Cone_eater's Avatar
I guess I just dont get it. It looks like it bolts to the stock AFM assembly, or does it bolt to the Throttle body?
Old 04-25-2012, 01:46 AM
Rogue_Ant
Rogue_Ant's Avatar
Here is another picture (not the same pipe, but should help convey the idea):
Old 04-25-2012, 01:58 AM
Cone_eater
Cone_eater's Avatar
oh, now I understand. I'm sorry. I was entirely confused, I apologize for my ignorance.
Old 04-25-2012, 01:59 AM
froby944
froby944's Avatar
Shoot me an alert when your ready to sell them. I'm in.
froby944 is offline
Old 04-25-2012, 02:04 AM
GTSilver944
GTSilver944's Avatar
Sweet. I'll be buying one.
GTSilver944 is offline
Quick Reply: 8v 2.5 NA MAF - Will It Ever Happen
