Failing coil?
Freedom Enthusiast
My S2 is acting up.
It has been loosing power while driving. I pulled up to a stop sign right near my house the other day and it just died. It will at times just lose power for a second or two. Other times it dies out for 10-30 seconds. If it dies and comes to a stop, It will restart if I let it sit for 10-15 minutes.
I've got fuel pressure. At first I was wondering if I had a plugged cat or if I had a failing TPS.
In doing some diagnosing, I pulled the coil wire off the distributor and laid the tip near a ground source. I had my son watch it while I cranked over the motor. He saw "little sparks". My next test was to put the coil wire back on and pull one of the spark plug wires. It fired right up. It fired right up no matter which one of the spark plug wires I pull. I can plug the wire back in and it will run on all four cylinders for a while before dying.
Is my coil starting to fail or could it be something else?
I have an S and not an S2, but I'm pretty sure we both have an ignition module below the driver side headlight and coolant reservoir...if that heats up significantly it can fail.
I had the same problem, only mine would die randomly and I'd lose instruments
Turned out mine was a combination of an alternator on it's last legs and a loose battery terminal.
Freedom Enthusiast
Would it give the same behavior of running on three cylinders when it was failing?
Did your car have the same three cylinder behavior?
yes--loosen the clamp for the power steering reservoir enough until you can get it out of its bracket, and then it's a clear shot.
a faulty ignition module will overheat and cause misfires. this happens a LOT on 80's and 90's domestic cars. it should be pretty hot to the touch when it's screwing up if you can catch it.
A coil can do that, as well, with the same heat issue...
Freedom Enthusiast
My car died at the stop sign that is about 100 yards from my house. I would be really surprised if the ignition module got hot in a 100 yard drive.
Also, would the failed ignition module kill the entire ignition or would it allow the car to run on three cylinders?
I had an issue the car would be running fine the just turn off . My issue was I believe to be a dirty connection on the bottoms side of the fuse box. I replaced my fuse box with a used one and cleaned the contacts and have not had any trouble since I believe if had only cleaned the contacts I would not have had to replace the box. Good luck let us know how you make out .
Freedom Enthusiast
I have two new DME relays in my glove box. I tried them both and neither one fixed the problem.
I replaced the coil and the problem appears to be gone.
