My Rear Ended S2 Repair in Progress
Here are yet more pics from last night. It was time to test fit the lights and check some gaps before I start going crazy with the welder.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Its really pretty easy. I cut the top section down the gap lines. Where the bottom meets the r-quarters it is spot welded and seemed in and with a little patience it all comes apart fairly easily. I used a cut wheel and a saws-all.
Separating the loweer boxed section that says Porsche is the hardest. I cut the top section from the inside and the bottom section just above the radius on the outside. I can take picks if you need them.
