How bad are solid motor and tranny mounts?
Old 03-07-2012, 08:11 PM
CO951
CO951's Avatar
Default How bad are solid motor and tranny mounts?
One of the motor mounts in my 951 has been collapsed as long as I've owned the car and solid mounts are a lot cheaper the other reliable aftermarket mounts, but how bad are they? My car is used for a combination of street and track. Since the current mount is collaped I wonder if I would even notice much. I currently get quite a bit of vibration at idle, but I'm used to it and I don't expect this car to be a luxury ride.
With this in mind how bad are the torsion tube or tranny solid mounts?
Thanks!
Old 03-07-2012, 08:54 PM
MAGK944
MAGK944's Avatar
Even your collapsed mounts have some rubber isolating the engine. Solid engine mounts do not and will transmit any engine noise directly to the chassis rails and throughout the car. Same with solid trans mount, it's noisy any annoying on a street car.
You can always urethane the trans mount and fit semi solid engine mounts, I think Lindsey has them but I still prefer the factory engine mounts.
Old 03-07-2012, 09:07 PM
LuigiVampa
WRONGLY ACCUSED!
LuigiVampa's Avatar
Received 4,065 Likes on 1,825 Posts
I agree - solid mounts are harsh and I don't think the minuscule performance gains negate the extra noise and vibration. I also tend to think it is not a positive thing to transmit all the road bumps back into the engine.
Old 03-07-2012, 10:34 PM
nasty9er
nasty9er's Avatar
solid mounts on a street car would rattle your filling out!
as far as replacement what brands are good or should your stick with OEM?
Old 03-07-2012, 11:01 PM
dillon410021
dillon410021's Avatar
I like the solid trans mount since it help prevent breaking axles/ cv joints. as for the engine mounts, I got the LR ultra mounts
Old 03-07-2012, 11:07 PM
87944turbo
87944turbo's Avatar
^ thats what I have, works great.
Old 03-07-2012, 11:47 PM
doabarrelroll
doabarrelroll's Avatar
Maybe think about trying the semi-solid style. I don't notice much of a difference over the stock rubber mounts with those.
Old 03-08-2012, 12:45 AM
nasty9er
nasty9er's Avatar
did any of you use the shims or did you lower the engine 10mm?
Old 03-08-2012, 09:01 AM
JohnKoaWood
JohnKoaWood's Avatar
Had the solid mounts, hated them, had stock mounts, and they were OK.. ended up at semi solid mounts, and IMHO they offer the best of both worlds... firm enough to prevent excess movement, yet not so rigid to transmit 100% of the noise to the chassis of the car!
I LOVE reading comments such as "they will rattle your fillings out".. as these comments are by someone who has NEVER used a product, but feels the need to weigh in on it...
I also have solid (elephant racing) suspension monoball inserts in place of the stock rubber bushings... and yes all my fillings are still in place! That having been said, my 951 is all semi solid engine and trans, with teh elephant racing monoballs in the suspension, my N/A is new stock rubber bushings with new stock rubber engine mounts and semi solid trans mount.. for the N/A that I daily drive 120 miles this setup works without making me tired at the end of the day.. the 951 is MUCH more demanding of attention durring driving!
Old 03-08-2012, 10:14 AM
nasty9er
nasty9er's Avatar
gezzz just trying to have some fun i was really just going off of what alot of plp here have said
maybe i should stop rennlisting late night after a few
so it seems most plp like the LR semi soild
Old 03-08-2012, 11:05 AM
CO951
CO951's Avatar
Thanks for the advice. The LR Ultra mounts looked like the best option on paper, except for their price. I was just hoping I could get by with the cheaper solid mounts, but it sounds like it's worth the extra money to go with the semi-solid.
Old 03-08-2012, 12:27 PM
azbanks
Freedom Enthusiast
azbanks's Avatar
I had the ultra mounts(engine and trans). I liked them.
Old 03-08-2012, 12:44 PM
xschop
xschop's Avatar
I redesigned the polyurethane mounts to convert from the 944 factory setting or the V8 swap....0.5" setback
Old 03-08-2012, 01:23 PM
JohnKoaWood
Have never used the LR mounts (other than the solid ones).. so I cannot comment..
Old 03-08-2012, 03:40 PM
87944turbo
87944turbo's Avatar
I used one set of shims, so 5mm. I was able to find my ultra mounts used. They came from a race car that was just built and blew up on a dyno before completing a single race, so basically new. They are not easy to find, but they are out there.
Quick Reply: How bad are solid motor and tranny mounts?
