Transmission drain plug size?
Time Warp: Both plugs are the same size, looks like 24x1.5 is correct. I've got a call into my "guru" to see where he got "25" for the drain plug.
Tim, does your tranny have the cooler loop? If so, could you put a tee fitting inline with the cooler and get a temp sender in that? I don't know the thread, but something like this:
http://www.summitracing.com/parts/VAR-92846/
On the 25, is he in software? We get things 'off by one' all the time.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Rich
Rich
Here is an idea. Some late model N/A cars have a plug on the drivers side of the oil pan where the Turbo oil return banjo would go. I believe this is M24 and has a head that would be good for tapping a sensor into. Maybe it could be used on the tranny drain plug?
I installed one of these, but it looks like it would be easy to drill out for your purpose.
http://www.ecstuning.com/Volkswagen-Jetta_I--8v/ES6998/
Work, wedding, stuff have kept me from the garage. Got back into it a little while ago. I had a spare 1/8" NPT to M16x1.5 adapter sitting unused in my pile. So I decided to weld an m16 nut to the drain plug (after drilling a hole through the plug) and then screw in the adapter and sender.
Flogged the car at Barber this weekend, temps in the low 70's. Trans/diff oil temperature never exceeded 190oF. Just as a reminder, I'm running a turbo S trans with stock cooler.
Engine oil was 210, water was 220.
50/50 Redline 75W90 and 75W90NS
