Transmission drain plug size?
Anyone know the size on the drain plug. Not the size of the hex needed to remove, the actual plug size (ie, 1/2 NPT)? Why, I'm looking for a simple solution for measuring trans oil temps. Easiest solution is to find a sender, or adapter, that will fit in the drain plug hole.
Good idea - I think the plug is 22mm but I'll take a look and see if I can find the old one to measure.
Might be time to start a thread "Telemetry: things to measure on a 944 and how to measure them".
C
C
WRONGLY ACCUSED!
Received 3,277 Likes
The way I normally figure stuff like this out is to take the bolt or nut and go to a parts store which has the nuts and bolts available see what fits. I know this is kind of a "duh" answer but it works.
Or you could just buy a new one from Pelican and drill a whole in it:
http://www.pelicanparts.com/cgi-bin/...9%2C%20Each%20
WRONGLY ACCUSED!
PET calls it out as an M24 x 1.5. I would swear it's a taper thread, 24mm would be real close to 1/2"NPT, but I would expect the Germans to use ISO tapered threads, which are not the same as NPT.
The sender head will just barely fit, so close that you cannot get a wrench or socket on it to completely screw it in, I tried!
I was looking on this website for a possible answer (http://www.conexmetals.com/thread/iso-coarse-thread.htm). I will measure the plug I have but I am pretty sure it is tapered. If not, I wouldn't expect it to seal.
OR you could always drill and tap a different location on the case... bottom of the case would be prefereable to make sure the sender is always within the fluid.
I would then have to use a pipe wrench to install/remove the plug as the sender would need to be removed prior to using the allen head.
Depending on the sensor... type you could try to source a low profile sensor, and recess the allen wrench to fit over the sensor (I actually have 3 different tools for the trans plugs, the largest of which is a simple 17mm? allen wrench from sears), or extend the walls of the plug to accept a wrench... just thinking outside the box here...
Rainman
is the plug aluminum or steel? if steel, get a nut that fits in the allen socket and weld it, and put the sender inside the nut. then remove the plug as a whole with a standard wrench.
if al, tack an AN fitting with shoulders for a wrench to the plug
It's definitely metric, as apposed to NPT. For my trans cooler, I welded a steel -10AN fitting on a stock plug.
Any reason why you don't want to just measure temp from the outside of the case? Much cleaner.
I picked up some of these: http://www.paperthermometer.com/pages/indust.html#8temp - but haven't actually used them yet.
How about something like this, they have a couple thread sizes, and use a reducer if needed:
http://www.mooreparts.com/store/product/3589/VDO323064/
