Potential Engine Purchase
I found this engine on ebay and am contemplating buying it. I have a 944 N/A Auto with a slightly blown head gasket so I'm thinking about swapping this engine into it for a little while. Are engines swappable between manual and automatic (I'm not positive his engine came from a manual)? This is a late 85 N/A engine and I have an 88 N/A, any problems there? How's the price, can I talk him down at all? This engine is about 4.5 hours away from me, is it worth it to drive that far for this thing? The engine number is 43F01796. I'm looking for some honest advice, thanks guys.
http://www.ebay.com/itm/110831099576...#ht_500wt_1000
it will bolt in. your auto stuff will swap over. you might consider using the manual clutch setup to replace the rubber flexplate on your auto though.
For $150 you can get all the seals and gaskets you need to simply remove and replace the head gasket on your motor. That is in fact alot easier job that doing and engine change. I just swapped heads on my race motor after I missed a shift and bent all my valves. Much easier job than swapping motors. Which I have done as well.
The only issues is that one you remove the head you should have it cleaned and decked for flatness. Most if not all old heads have corrosion holes in them. No big deal for a good head shop to work on. Plus this work will get you alittle more hp too as these cars will lose power when you have valves that do not seat well.
If I were my car I would pull the head, have it worked on and reinstall. Oh while you are inthere change the t-belt if you have not done so lately.
In that case, I guess I'll just go ahead and order the head gasket, where's the best place to get it? I was just gonna order it from Pelican, but which one? Anything else I should do to the head or block while I'm that deep into the engine? Do I need to get any of the special tools from Arnn Worx?
Sorry for all the questions, but I appreciate the help.
Sunday I just put a my replacement head on the car it was 4 hrs incuding a lunch break. I order my stuff from paragon-products.
Head gakset, cam housing gasket, intake manifold gaskets and exhaust gaskets. Because I was installing a different head I also put new gaksets for the forward cooling hose port and for the rear heater port.
The only special tools you need are 8 mm allen for taking off the caps on the cam box and then a long 6mm to get the cam housing bolts off. Most sockets won't fit in the holes to get the 6 bolts under the those covers. Remember to shock the cam housing bolts. Take you socket and extenstion and give them a good firm wack with a hammer. This with shock the bolt and make it easier to loosen. You can leave the headers on the head if you want, but if you wil get it machined loosen the nuts on the head first. It will be easier with the head tight on the block as you will not have to worry about holding it as you loosen those nuts.
I keep my fuel rail and injectors plugged in and just move them out of the way. The Intake manifold needs to come loose, but can stay in the car to fewerlines to unplug on that.
Watch out for the liftes when you pull the cam housing. They will want to fall out and also make sure you keep an eye on the two aligment pins between the cam hsg and the head.
