Brake banaza!
If i was going to do anything it would be the wilwoods, then i would at least be losing enough weight to make it almost worth it. Otherwise, fresh calipers, SS brake lines, full system flush/bleed with ate type 200, new pads and your good to go. Maybe the 944S 5/33 rear brake valve for more rear brake if your feeling spicy.
i ended up getting my kit second hand (but never mounted) at a discounted price. the new pads, brake fluid, stainless steel lines, weight reduction, and ease of pad changes was well worth the cost of admission.
Refresh your stock brakes, take the money you save and do a couple DE days to learn how well they work.
Running R compounds with a stock NA I've never needed more brakes.....now more motor....
