Brake banaza!
Brake banaza!
I just had an epiphany. So lets say i upgrade my front calipers to what ever, could i bolt my front calipers to the rear to improve the rear braking?! or am i just a uneducated confused 17 year old?
1985.5 944 na
1985.5 944 na
Yup. Thats what i did to the 968 when I put big blacks on the front and put the 968 front callipers on the back and put in a 928 proportioning valve. Brake so hard it'll pull the eyeballs out of your head.
There is no cheap. Become a member and you'll be able to see the For Sale forum. That's where I got the big blacks and cryogenically treated rotors for $900. Realistically you don't need to go there with a 944. Best to get pads that work in the range you intend to drive and a 944 works best by not slowing and if you have to, put it sideways to scrub speed.
Rennbay has a nice wilwood setup for the front of an n/a, not cheap but not horribly expensive. Also turbo brakes are a good upgrade, but I think depending on year of your car, you might have to also swap the hubs/spindles or something.
Stock brakes are just fine for most if not all 944 owners. I wouldnt waste my money. Why not just refresh them? New rubber lines, good pads, and brake flush. Just doing that made my good feeling brakes feel better.
They're for sure different.
Look on here and on 944 hybrids and the stuff that xschop has come up with for big brake kits. He's got one now for mounting a boxter rotor and wilwood superlites to the N/A spindle or something.
If i was going to do anything it would be the wilwoods, then i would at least be losing enough weight to make it almost worth it. Otherwise, fresh calipers, SS brake lines, full system flush/bleed with ate type 200, new pads and your good to go. Maybe the 944S 5/33 rear brake valve for more rear brake if your feeling spicy.
