Cracked rotor
Cracked rotor
Well my car sat for about 3 months and when I got it up on the lift to start the clutch I did a inspection and i found a little surprise. A nice crack that is almost the full length of the rotor surface. It seems like the rotor still has plenty of meat left.
Any ideas why this happened?
Am I in danger of the rotor disintegrating during a spirited driving session?dan[IMG][/IMG]
haha thats what i figured. well another excuse to upgrade... Slotted rotors look sweet. But i don't want to start yet another slotted/drilled/oem. so i shall leave it at that.
Thank You carlege
Thank You carlege
[QUOTE=Dimitri_944;9303622]Well my car sat for about 3 months and when I got it up on the lift to start the clutch I did a inspection and i found a little surprise. A nice crack that is almost the full length of the rotor surface. It seems like the rotor still has plenty of meat left.
Don't have any idea why it's crack like this,but I wouln't drive the car even less spririt drive it with a crack rotor.Not only will you put yourself in danger but also other peoples around you,if it does breake at higth speed your gone to loose control of the car. Once had one (not on my 944 but a DD) break on me at low speed around 35 MPH & lol had a hard time to regain control.It did ruin the caliper/pads.
okay the car is off the road for a clutch replacement so i will try and scrape up some money to buy some new ones before i put it back on the road.
Thanks Ernie
Thanks Ernie
look at it as a good time to inspect and re-pack the wheel bearings...
Dimitri_944 what year is your car and what model(N/A Turbo)? i have an 83 944n/a parts car that still has ss lines and all 4 rotors and i am only a stones throw away so if you dont feel like buying a new one just let me know
