16V Timing Chain/Tensioner Elimination Kit..Feeler
I'm developing a alternative cam drive system that will eliminate the timing chain and tensioner from 16V heads and replace it with an external belt drive. It would allow the use of heads that have the tensioner boss broken off, would be more reliable, and easier/less expensive to maintain. I'm expecting the it to cost about $700 to $900 and I a planning to have it ready around August or September. I just wanted to see if anyone else had any interest in it so I can decide if I want to put together more than just a few kits for myself.
I would like to see what you end up developing. I have not had a problem yet , but it looks like weakness in the factory design , That could use a different approach. John
Administrator - "Tyson"
Get your hands on some 928 heads - same overall design (different cam gears).
If your setup does work on the 944S, it could be adaptable to the 928 and you will have a huge market there.
Will this be similar to the twin pulley setup that David Chen developed back in the late 90's? (two exhaust cams, with dual cam pulleys, that are smaller than stock [to clear the hood] and a matching crank pulley)
This would be nice for a head that was wrecked, but there's nothing wrong with a well maintained cam drive setup on the 16v head. For $900 you could replace the chain tensioner twice...
Right now I am just focusing on 16V 944 heads. If it works out, I can always look at the 928 heads in the future if there is a need.
It's a bonus eliminating a system that is more prone to failure than a dual gear setup.
Not to mention when the stock system fails, it's a lot more than your head that's subject to destruction.
Less than 100,000 miles no my car when the chain snapped. This was less than 6 months after a dealership "inspected" the system and said all was good (this was 1998 or so).
My head wasn't damaged, my valves were not bent, both camshafts were destroyed - over $1,000 each from Porsche
Not sure this system will be more reliable. Here's why-
Say we have 100 S's out there. 9 will grenade from broken timing belts and 1 from tensioner/chain failure in the next 10 years. Best you can do is go from 90% to 91% reliability if your your belt system is no less reliable than what the engineers at Porsche designed.
These numbers are made up to make the point, but you'll need to know them before you will know what you have done to the reliability.
The sad reality is that the timing chains on my old Mercedes diesel and both the e28 535 and e39 540 will last forever, and the timing belts fail alla time, and you have to replace everything at half the recommended interval. Feh.
Regards,
doug
86 951 (http://www.pcaucr.org/visuals/photos...egory&catid=61)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
the way i see it is, with this kit you are eliminating one of the two potential causes of failure: 1. timing belt failure 2. tensioner failure (caused by loss of oil pressure by a leak/crack in feedline, or failure of the tensioner itself). now if an existing timing belt application for this kit had a gates kevlar timing belt available, then we could address both issues.
Might be irrelevant, but I always remember that chains are much more deeply embedded in the Porsche Engineering culture than belts, no doubt about that:
