Whose sent their injectors to Witchhunter?
Old 01-24-2012, 12:44 PM
Hollywood D
Hollywood D's Avatar
Default Whose sent their injectors to Witchhunter?
Did you feel it was worth it? I'm getting ready to pull the manifold off and all that stuff. Since I'll have the fuel rail out I figure I may as well either get new injectors or send them in to be cleaned.
Witchhunter does them for $20 a piece of I can get rebuilt ones on pelican for $55 a piece. As I understand it after reading their website, witchhunter replaces the seals and everything right? So when I get them back they are ready to be reinstalled immediately (no other work needed?)?
Old 01-24-2012, 12:49 PM
V2Rocket
Rainman
V2Rocket's Avatar
I did this mid last year. Car seemed to have some more pep and the injectors even sounded better. Not to mention they were clean.
I sent them two sets - one of the injectors turned out to be dead so they didn't charge me anything for it.
Old 01-24-2012, 12:52 PM
MAGK944
MAGK944's Avatar
Cleaned, balanced, new seals & caps. You get a before/after report on condition, very happy - plug & play.
Old 01-24-2012, 01:38 PM
Lemming
Lemming's Avatar
I've used them a number of times and will use them again if needed.
Old 01-24-2012, 01:42 PM
fwb42
fwb42's Avatar
Nothing but good to say. Very quick turn-a-round. 1 week from Ohio and back.
Old 01-24-2012, 02:55 PM
doabarrelroll
doabarrelroll's Avatar
Really good service and quick turn around time. Highly recommend them.
Old 01-24-2012, 03:47 PM
f1rocks
f1rocks's Avatar
+1 for Witchunter
I send them injectors every two seasons. And I always have a spare "fresh" set in the trailer.
I had a set of rebuilt injectors and one leaked so bad it was unusable. I would vote WH over rebuilt even if the price were the same.
Old 01-24-2012, 04:21 PM
944CS
944CS's Avatar
I have sent 1 set of Turbo Injectors, they noticed 1 was leaky - but it's a good investment, they change the filters too
Old 01-24-2012, 06:53 PM
xsboost90
xsboost90's Avatar
ive sent them many sets. Always worth it.
Old 01-24-2012, 07:05 PM
Cosmatics951
Cosmatics951's Avatar
Yeah I've also used them twice, loved their service. One was out of spec so it was thrown out and I got a refurbed from them for next to nothing. Great product.
Old 01-24-2012, 07:10 PM
Hollywood D
Cool. I will be sending mine off soon then.
Old 01-24-2012, 07:52 PM
mytrplseven
mytrplseven's Avatar
When I pulled my intake to fix old vacuum lines, AOS seals and a number of other things, I sent my injectors to Witch Hunter. I got back bench test data before and after, all the seals replaced, they were cleaned, painted and individually bagged. It was quick turn around and they recommend you install them within 30 days. don't know why but I put them back in after cleaning the top of the motor, media blasting the intake and repainting it with VHT. I give them top marks and haven't heard of any negative reviews by anyone.
Old 01-24-2012, 07:57 PM
Hollywood D
Speaking of AOS seals, does the oil need to be drained to do that? As I understand it, the filler neck needs to be taken off completely.
Old 01-24-2012, 09:40 PM
xsboost90
xsboost90's Avatar
shouldnt need to drain the oil. Not nearly that high...
Old 01-25-2012, 07:20 AM
Toran
Toran's Avatar
Sent Witchhunter two sets and got them returned quickly with data details. I will use them again!
Quick Reply: Whose sent their injectors to Witchhunter?
