radio cuts out when I engage the clutch?
Old 10-23-2011, 09:53 PM
z8virginia
z8virginia's Avatar
Default radio cuts out when I engage the clutch?
Any thoughts on this problem? When I engage the clutch, the radio turns off. I had hoped for a pinched wire, but cannot see anything. It happens in the first 1/2 inch of travel on the clutch. I notice there is an electrical switch tied to the clutch pedal - what does it do? Could it be the problem?
Any help or advice would be greatly appreciated.
Old 10-23-2011, 10:20 PM
Hollywood D
Hollywood D's Avatar
I don't know what that wire does, but have you ever cleaned your grounds? I cleaned mine up and other things started working that didn't before, such as the light for the parking brake.
Old 10-23-2011, 10:24 PM
SeaCay
Thefu
SeaCay's Avatar
Part of the function of the switch on the clutch is to disengage the cruise control when the pedal is depressed. There is no function related to the radio in a "normal" car. Now, a PO may have wired the radio in any number of idiotic ways that may make abnormal operation normal.
How butchered is the radio wiring?
Old 10-24-2011, 08:30 PM
Rudeboy42
Rudeboy42's Avatar
I have to say this is one of the weirdest problems I've ever heard. I'm so curious as to what it could be
Old 10-24-2011, 09:16 PM
teamking
teamking's Avatar
OK, first find out of it's related to the switch or the pedal.
Press the clutch: radio should go off.
With clutch pedal pressed, use your finger to press the switch.
If radio does not come on, (and you should hope this is the case) => mechanical problem related to clutch pedal pulling on some wiring. Re-route the wiring. Problem solved.
If radio comes on => electrical problem. I don't know even where to start. Maybe a short. You could pull the radio and probe each of the pins and see which one changes when you press the clutch pedal. Trace that one back to the fuse box or just re-run the wire.
Good luck!
Old 10-24-2011, 09:44 PM
z8virginia
z8virginia's Avatar
Thanks guys. The search begins...
Old 10-24-2011, 11:51 PM
dirtyTurbo
dirtyTurbo's Avatar
Just have to say I loled my mcrib sandwich all over my monitor when I read the thread title
Only on a german car
Old 10-25-2011, 12:18 AM
stew-gart44
stew-gart44's Avatar
right after that happened to me last week my clutch died.....fml lol
Quick Reply: radio cuts out when I engage the clutch?
