Intake upgrade and dyno results
I've decided to experiment/upgrade the intake on my 944 NA. I am testing out my friend's set up shown below. Today, I had a few dyno runs on Dyno Jet and the 26-year-old track toy did 135 HP and 135 FT/LBS TQ !! I was pleasantly surprised because I was expecting lower number in all honesty.
Tomorrow, I will run it with stock and then with the set up in the pic below.
Stock set up
![](https://rennlist.com/forums/members/dimi-944-albums-induction-picture12116-stock-944-induction.jpg)
Experimental set up
![](https://rennlist.com/forums/members/dimi-944-albums-induction-picture12115-951-induction.jpg)
The car has stock exhaust and MaxHP chip.
The Dyno results of stock vs experimental set up are shown below (the blue line is the stock intake and the red line is experimental set up).
Stock set up
Experimental set up
![](https://lh5.googleusercontent.com/-Vgx2JhASQiM/Tp8-Pnh_A8I/AAAAAAAACTc/WzaDBsDDL-Y/s800/Stock%252520vs%252520947%252520Intake%252520Dyno%252520Results.jpg)
It is, generally longer runners favor lower rpms. Also the 951 plenum will be larger to account for boost. Interesting experiment but I think everything else being equal you will lose power with the 951 intake on the na.
1 Post
I'm very excited to see the results as well. Whether it works or not is not the point. Determining which is better for basic n/a engine is more important. If the n/a manifold is better, so be it, and we can move on to other ideas.
As for the final results, it looks like adapter to the AFM could make or break the results of this test. Do you have any pics or description of what that adapter is and how it transitions from a round to a square port?
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I just measured both of mine on the car. Used string to go around the bends from flange to plenum. Surprisingly the turbo intakes are all approx 13.5in and the na all approx 15in. So the na intakes are quite a bit longer. The plenums on both seem to be about the same, about 12in long.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Done testing the new intake set up!
Overall, there is no change in the average horsepower. However, between 5500 and 6400 rpm the car made 139 HP - gain of 4 HP. Between 2000 and 5000 rpm the car made 131-132 HP - loss of 4 HP.
Having in mind, I predominantly track the car the gain does help me. Also, my friend and I are working on an air scoop/collector to generate/simulate ram intake. This should lead to some power increase at speed. However, more than likely the mapping has to be changed because the ECM wouldn't know of the increased air flow/pressure at WOT at speed.
Btw, the car has stock exhaust and MaxHP chip.
Pending dyno graph and sheet....
I had it dyno'd at PF Supercars in Frederick, MD on a Dyno Jet.
Err... isn't the area under the curve that matters, not the peak? 4 hp lost over a 3000 rpm range is more than 4 hp over a 1400 rpm range. Ram air does not work at NA speeds.
