No Crank :( HELP MEEE!!!!!!!!!!!!!!!!!!!!!!!!!
The large lead on the starter should be 12 vdc and not go away when you try to start the engine.
There are 2 large leads on the starter one is connected to the alternator output and the 2nd lead is connected to the + terminal of the Battery. There is one small lead on the starter which should measure 12 vdc when the ignition key is held in the start position.
Hey, I changed DME and starter does get 12 but for some reason it loses it when you turn the key, even with a new battery in the car. Do you think is like a ground to the DME or something like that? Plus when you do cross the starter there is no spark while the are is turning
Do you hear anytining from fuel pump when in start position ? Most Bosch systems power fuel pump in start position, then when engine starts -key returns to run and a pulse sensor ( senses flywheel spinning - engine is running) and pulls in fuel pump relay .
I listened for fuel when I crossed the starter and the motor is turning with key in on position, and yes it does send fuel, but there is no spark and the tach does bounce so does that rule out the crank sensors for my spark issue?
