Engine installation
Engine installation
I will be installing a new motor into my 85 shortly and am wondering the best way to do it.
I know the manual, clarks garage says to install through the bottom, and it does seem easier, I am just concerned about having the car that high on jack stands.
I took the original motor out of the top, but dropped the cross member anyway.
Any one done it through the top without removing the trans and pushing back the torque tube.
with the oil filter, rotor, accessories, and power steering pulley off you can remove it without messing with the trans.
that said, removing the trans and pulling the tube back takes 45 minutes so...
On my n/a I went in and out the top, and regretted every minute of it. It is worlds easier to go out the bottom, and if you lay the engine on it's side on a piece of cardboard it will slide out without the car having to be very high
