Can you identify this cylinder head?
Old 08-17-2011, 04:29 PM
  #46
Olli Snellman
Olli Snellman's Avatar
Ok, i asked about the tensioner, because i have thought the possibility to use 968 arrangement on my S2 block; it's quite easy mod to do.
So you have gone even furter with ITB setup, last pictures i have seen had runners made from billet.
Old 08-17-2011, 04:46 PM
  #47
MAGK944
MAGK944's Avatar
Originally Posted by Van
Very cool project, I've always liked your stuff.
Off topic, does anyone have a VCR available? Seriously. My kids watch a lot of VHS tapes, but our VCR is dying.
Your local charity shop should have a few lying around, paid $10 for my last one.
Old 08-17-2011, 05:17 PM
  #48
ernie9468
ernie9468's Avatar
Talking
Originally Posted by mhr
didn't ernie say 968 back on the 1st page.
Originally Posted by michaelmount123
Yea, but I challenged it as a guess. He didn't say WHY it was a 968 like fortysixandtwo did. Oh, okay, you two guys fight over the prize. Remember, there's gift tax just like Opra.
No it wasn't a guess,now I want my darn VCR.Or else this guy will be knocking at your door shortly.
Old 08-17-2011, 07:06 PM
  #49
michaelmount123
michaelmount123's Avatar
[QUOTE=Olli Snellman;8798767]Ok, i asked about the tensioner, because i have thought the possibility to use 968 arrangement on my S2 block; it's quite easy mod to do.
Olli,
A conversion to the 968 tensioning arrangement would be cool, but quite frankly I haven't seen the need. The S2 system works fine and it's much quicker to release if any work needs to be done on the top end.
Yes, the new ITB system is a huge leap forward. I'll post pictures soon.
Cheers
Old 08-17-2011, 07:18 PM
  #50
michaelmount123
Ernie,
I think I might be starting to like guys...
Old 08-17-2011, 07:28 PM
  #51
michaelmount123
Scott at Team Harco,
You asked about the car this engine's going in. Here it is:
Old 08-17-2011, 08:26 PM
  #52
V2Rocket
Rainman
V2Rocket's Avatar
oh, so this is Henk's soon-to-be-Legendary engine...
Old 08-18-2011, 08:48 AM
  #53
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Very nice! Thanks for posting.
Good luck with the build and the racing.
Old 08-18-2011, 03:22 PM
  #54
Olli Snellman
looking forward to see pictures. I still play with the idea to have ITB's with my 16V turbo project engine.
Old 08-18-2011, 04:11 PM
  #55
michaelmount123
Thanks Scott!
M.
Old 08-18-2011, 05:19 PM
  #56
Duke
Duke's Avatar
Very interesting project!
I could use that head & cam-combo on my 3.0l 16v turbo
Old 08-22-2011, 03:34 AM
  #57
HJK
HJK's Avatar
Old 08-25-2011, 05:42 AM
  #58
333pg333
333pg333's Avatar
Michael, firstly, stirring stuff indeed. Beautiful to look at. Can't wait to see this beast up and running. Hopefully you can grace us with some video on the engine dyno?
From what I understand you have specialised in n/a motors but I'd be curious what you would change to go with forced induction. I'm sure Henk has probably discussed this with you as I know he was toying with a turbo or S/C'd motor in the past. What pistons and c/r are you using in this motor? Rods?
Old 08-25-2011, 02:08 PM
  #59
michaelmount123
Thanks for the positive comments, Patrick. Music to my ears...
I do forced induction stuff too, just not as much as the n/a. Preparation is not all that different; obviously c/r, and different camshaft profiles/timing. Much of the other prep is the same. A boosted engine 'thinks' it's larger in displacement than it physically is (lots of free power) but it responds to all the same performance modifications as a n/a engine does. Head work, intake design, cylinder prep, piston sealing, etc, etc. are equally important in both engines to maximize power.
Henk's engine is 12.5:1 compression. It's conservative due to the fuel he will be running in Thailand. Rods are Pauter's latest design. I went with Honda big ends, 22mm pins, and additional length over a standard 944. Pistons are JE and also made to spec. They have a box skirt design (ala F1), with a very short skirt, with a few additional mods for increased ring seal. Remind me and I'll post a photo of one. They're quite nice.
I did an engine for an Aussie a while back. It was a bit of a challenge, since your engines run counter-clockwise (I think you call it anti-clockwise). Anyway, I had special cams made, machined a special impeller for the water pump, and re-wired the starter so it would run backwards. Once on the dyno there were ignition errors galore... I finally figured out I also had to connect the battery backwards so the Aussie program in the ECU was happy. In the end, I think I got it right.
Cheers,
M.
Old 08-25-2011, 02:43 PM
  #60
Van
Van's Avatar
Don't they use Fosters for fuel down-under?
Quick Reply: Can you identify this cylinder head?
