Ground Control vs Racer's Edge Camber Plates?
I've got Racer's Edge camber plates and the spherical bearings on the passenger side are shot, with the driver side not far behind.
I could send these back to Racer's Edge for replacement bearings but these don't have that many miles on them so I'm not sure I want to go down that route again.
Are the Ground Control camber plates, with the needle bearings, a more robust option?
Part of the short lifespace of the Racer's Edge units may have been due to the unbelievably harsh intrax setup I tried out that has since been dialed down to more reasonable spring and damper rates.
Nice. Same reason I designed my own arms with the early ball-joints
You're just going to have to replace the sphericals now and then and hope that all the harsh stress is now not being transfered to the spot-welded rear control arm nuts that are inside the body
Just removed my Ground Control ones and put on Racers Edge ones. RE ones ars MUCH beefier. The GC ones also have a shoddy caster adjust which is more detremental than helpful. The RE ones allow for full travel and a favorable instant center. The RE ones are also about twice as thick. The GC units "feel" like they have more slop in them, but that can't really be confirmed without measuring equipment.
I will be putting the GC ones on my street car. But they just don't seem robust enough for a track application.
If I were you, I would send them back. Karl stands behind his stuff. Unless you want to swap them straight up for my GC's! :-)
Now that's an interesting idea... It might be worth the swap just to keep the car mobile if you can be patient while I swap them out.
I'm happy to send the plates back to Karl but I have one of those NYC situations where there's no convenient place to immobilize the car while it's in pieces.
But what I'm hearing from you is that I should refurb my RE units rather than go with new GC's.
40,000km on mine and counting.
Cheers,
Mike
It's a long story and will involve a well known vendor here who advised me to trust what intrax shipped for a street/track car.
I don't want to get into it but needless to say it was completely wrong. they were 750 in front.
