lost fan speeds 1-3 onl yhave high
I am using my A/C yesterday, when the fan stops working. Now, it only works on the highest speed, A/C still blows cold. Any thoughts.
1987 is the year.
1987 is the year.
Fan Speed Resistor...
Had this problem on several other cars of mine... might even smell like burning sometimes...?
http://944time.com/porsche/944-fan-speed-resistor.php
Check this out ^
Check this out ^
Vinegar works great. It's a weak acetic acid. White is cleanest.
You might stick some toothpicks in the contacts' arms to hold them open during the soak to get better exposure.
Well I soaked the part in the Vinegar. I was not sure of this, but you all said it would work. Well it did and i have fan speeds again. Imagine, a simple solution that could have costs big bucks to fix. Thanks to you all for you input.
