Has anyone run into this - Brakes
88 951 - Changed out the rear rotors, new pads, bled the brakes. All good, till I tried to back out of the garage. Acts like the rears are locked up or very tight.
Pulled everything back off and checked everything again, the only thing I do noticed is it looks like the pads are thicker than I remember new ones being. Anyone know the thickness of what a new pad should be?
Did you check your parking brake or re-adjust them? The old rotors might have been worn from the parking brake dragging at some point and now the shoes are tight. I'm always amazed how thick new pads are on a 951. Another thing it could be the caliper pistons have been sort of frozen to a set return position that sits a bit outside for brand new pads and rotors. I've always had to push them in as far as they will go just to install new pads and rotors.
When you pulled the calipers to replace the rotors were there spacer washers between the caliper and control arm mounting ears? I know my ‘89T has them and I would find it difficult to assemble without them in place… just a thought.
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
exactly.
that's the mistake i made. and then remembered i don't do brakes, and this is why. but, i dug around in the dirt, found them, and all was well.
