Newb Here Looking to buy a 924S
So I've been lurking for a few days and Boy, am I glad i found this community. I Found a 1987 924S i really want to buy its 500 buxs and in good shape, however it starts up and then dies. Do you guys think its a relay or the DME. Any advice is appreciated cause Im driving down tonight to tow it back home and will post pictures.
There is a large vacuum hose that plugs into the bottom of the Intake J-Boot... If this is not plugged in -->the engine will do exactly what you described... (Had this happen several times after working on my car)
A simply check for starters
germantrader10.....if it's off, do the deal FIRST, then put the hose back on and start it.
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
First thing CHECK timing -balance shafts belts ASP,if those break while attempting to start & run the car you can ruin the head.All you have to do is remove the front belts cover off & check if the belts are ok.This is what you'll be looking at once the cover is remove.If you have any doubt about those belts condition do not start or run the car before replacing them.
No, you will be towing that home.
Bad fuel, bad fuel pump, bad FPR, bad hoses, bad injectors and a host of other things can cause that.
Just get it home to where you can work on it and start working through the issues (is there fuel at the rail? Is the pressure OK? etc. etc.).
Us idiots will be here to help.
Oh...that's different that what you first said.
Second....Ditto to all the above.....
Sounds like a fuel delivery issue to me as well.
Bookmark this site, clark's garage, 944online, peligan etc. I know one of these sites has a 944 issues checklist on it somewhere. The guys here are very good, just take it one step at a time and check the simple stuff first. Disreguard the 'check the flux capacitor' suggestions.
michael
+1
It is a well know fact that the flux capacitors in these cars will long outlast the cars themselves and never need to be maintained, much less be wrenched on by home-garage amateurs such as ourselves. Muffler bearings need to be replaced regularly though.
