Part # for the rock gaurds in front of the rear wheels?
Recently had my drivers side repainted and I need to get the rock guard. Shop didn't put it on, they want the paint to cure some first.
Figured I'd replace both, anyone know the part #'s and cost?
TIA!
TIA!
Here's where I bought my rear replacement last fall...need to get around to the fronts now.
http://www.paragon-products.com/Pain...p/sg_944oe.htm
944-559-326-00-3YK-M260
944-559-325-00-3YK-M260
OEM part numbers.
I bought from this place.
http://www.autotrimdesign.net/detail...Guard_Kit.html
haven't been able to put it on yet, but it looks decent. Only complaint would be the long order processing time... I assume they don't keep them stocked. ~2 weeks.
OEM part numbers.
Best way to DIY take the old stuff off? I am purchasing an 88 951 and these film protectors have discolored and cracked. I want to remove and replace myself so any help would be appreciated.
Lane
Lane
I don't have stone guards but, if i were to install them; i would go the 911 route. I think they look great!
https://rennlist.com/forums/924-931-...ied-these.html
The Funny thing is: My Car has hundreds of rock chips, (All of them happend last year while commuting from Baltimore to DC everyday
*But none of the rock chips are where the stone guards would be...
the "best" way is to learn patience first. I used a heat gun, various plastic scrappers, and 3-M adhesive remover or Goo Gone. It takes 45-60 minutes per piece IIRC. Probably the best tool I used was a set of plastic "chisels" from Harbor Freight. They were stiff enough to get the goo off but would not scratch the finish.
The key word is patience. As mentioned already it is just a process of going back and forth from heat, googone, and plastic scraping. I also did a lot of fingernail scraping.
