ID of '86 NA torque tube shaft????
Does anyone happen to know the inner diameter (past the chamfer) of the torque tube at the engine end? I have the engine out, however the drive shaft itself makes it virtually impossible to measure with the calipers I have. I'm wondering if anyone happens to know the measurement, or has the ability to measure a tube without the drive shaft in it.
Basically I need a very accurate measurement to make an adapter plate for an engine swap. I would like to use the inner surface of the tube to center the adapter plate, it appears the 3 dowels on the back of bellhousing were used to center the stock engine. (it's hard to get much from the 3 dowels since you can't directly measure diameter from 3 points of a circle)
Any help would be greatly appreciated.
3.05" (77.47mm) sounds about right, I was getting around 77mm with my crude measurements.
If you could easily confirm I would be very grateful.
Instead of dicking around with the dowels, measure the bellhousing circle it fits into...
I hope you're going to have some controller that limits torque output at low RPM!
To make this thread useful for anyone else searching for this information, the thread is located at:
http://944hybrids.forumotion.com/t19-c5-bh-adapter
The torque tube ID is 3.0312"
Thanks again!
