Clutch Master Rerplace or rebuild?
My clutch pedal is starting to stick on release more and more. I decided to slide into the most uncomfortable position I could possibly think of and see if adjusting the rod and spring would help. It did not!
I did pull the boot off and had quite a bit of fluid pour out. I'm fairly certain the m/c is going out. So has anyone rebuilt these or is it just easier to replace it. I have rebuilt MG and Spitfire masters and slaves but not Porsches'
any thoughts would be helpful
Its only a $65 part, just buy a new one. I actually just replaced my MC. I also recommend replacing the slave cylinder as well if it is still original. My slave failed in 2007 and I replaced it, 2011 comes around and the master fails, might as well do it in one shot. Others will agree as well.
Thanks for the reply's. That's what I thought, but I thought I'd ask anyways. And good call on the scoring Andy. I did have that problem with my spitfire brake master once. I just wasn't thinking about it until you said something.
