1983 euro 944 specs?
i have a 944 that was imported from germany and i am having some serious trouble finding some specs on it. i found one source saying 1982 944's (which would be a non us version like mine) had 15 more horsepower ( putting them at 161) and weighed in at only 2600lbs. does anyone know for sure? if this is true then performance would be significantly better than a us model. i apreciate the help
Source
Source
Rainman
yes the earliest euros were lightweights with no ac, power steering or power sunroof (hence no supporting hardware). crank is shorter for earliest factory ps-delete cars which saves a little weight etc...
high compression pistons + no catalyst and some other things makes output around 163hp.
okay thanks for the conformation on that, i got the manuel steering/sunroof. sweet thats good news, that should put my car around the 2.7 liters performance with 200 pounds less weight. sounds like a winning combo to me.
Euro 2.7L had more or less same power figures as euro 2.5L had. 2.7L was just a way to save money when factory made only "one-size-fits-all" style blocks for 8V & 16V configurations.
