Quick question for the parts guys.. pop-up removal
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
When you remove a pop-up headlight unit from the car (just the actual headlight bucket that moves on it's hinges via the linkage), how do you disengage it from the linkage?
There's a circlip holding on a washer, but after taking that off, the headlight unit still doesn't want to come away from the joint at the linkage... it's like a small ball joint.
How do you release it from the linkage? Is there some trick to getting the joint apart, or is just a bit of brute force required?
