Left/Right wheel well speaker box?
I'm going to go simple and just aim for a single small sub (8") and make a box similar to a KLA box. I am not a pro, but I have 10-12 speaker boxes under my belt, but were primarily built for larger hatchback and large domestic car trunk setups. I already have a 2ch MTX amp in the rear, but it would not be hard to put in a 4channel and do a bridge to a single sub. I am now looking at adding my two rear speakers (6.5") from my custom box, and trying to fit them in the rear seat side panels. I'll have to pull off the panel and have a good look. I did find some pics of stripped out interiors, and it looks like a hole for a speaker is present in all 944's in that area, so I will take a chance and pull it apart to be sure I can fit my speakers there.
Thanks!
Thanks!
I think his cab was a conversion not a stock porsche one.
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Ernie those photos are awesome i actually am working out where to put my sub enclosure as well i did the rear seat replacement but it turned out heavy as hell, then i tried a simple box in the hatch area but it moved around to much so i ended up and made it fit in the space behind the driver seat and the rear seats
i also wanted to keep all the cargo space i had in the back of my car after doing my seat delete...... but, it was demonstrated to me that running any combinations of 8" or 10" mid bass drivers or subwoofers in the rear corners of my car probably would not result in producing very high sound pressure levels without suffering a lot of interference.... that is to say, the result would likely see some pretty bad "holes" across a significant part of the audio band. three different installers all had the same opinion, (especially if i went with a pair of subs back there.... that properly angling two drivers not to be fighting each other would take a lot of trial and error, and might even prove next to impossible.
so, i was convinced to try 1 10" duel-coil subwoofer first, (in effect combining both left and right bass waves into 1) as "this" would almost surely have just the opposite effect, with the shape of the rear corner of the car working in harmony with a single, point-source sub cab to create a very strong bass wave.... and see how that turned out.... well, that's exactly what happened...
I have been involved heavily in car audio for over 30 years and can't believe how many ppl in the industry just don't know what they are talking about. Going for a sub on each side would result in great bass and would not present any standing wave issues.
I have just started building a box for a single 10 in the rear corner. It is designed to fit to the cover so I can still get access to the storage area underneath. It will end up with a carbon fibre fascia(front baffle) when its finished.
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs258.snc6/180663_1825781645856_1279731767_2182706_1041140_n.jpg)
peace
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
my bad (not my installer)... you're absolutely right... it's a mono amp sending a single mono signal processed from both sides... i had him build me a speaker box and flip the on/off switch to on. it's clean w/ rich, deep bass.... as one of the guys mentioned, 1 sub already adds weight. i didn't really want more, so when my installer suggested i'd likely get the cleanest basswave from a single source, i said, "ok..." and whether he turned out to be right or wrong, is not something i've fought over for every last decibel. i'm convinced that it worked.
my home system deserves a listen... not running the B & W Nautilus sats and Krell subs, but what i am running is pretty close in the loudness department and not bad stuff for under $20 k. anyway, back to bed.
Nakamichi CD.
Audio Research tube pre amp
twin Sunfire Amps
JBL pro. "can't buy anywhere sats." get so loud you might die... original owner paid about 12 grand for these.
Ground Zero engineering subs.
Nakamichi CD.
twin Sunfire Amps
Team Owner
my home system deserves a listen... not running B & W Nautilus sats and Krell subs but,
Nakamichi CD.
Adcom signal processor
Audio Research pre amp (yeah, the one with tubes).
2 Sunfire 600 watt/channel stereo amps....
JBL pro. "can't buy anywhere sats." get so loud you might die... each consists of 1 8" midbass driver, 1 8" fullrange driver, 4" midrange and tweeter... just a few of these cabinets were made by JBL for recording studios..... original owner paid about 12 grand for these amazing loudspeakers.
Ground Zero engineering subs (just the drivers weight about 25 kg each). they might be the loudest 10" subs ever built and can handle 3,000 watts each... i was lucky enough to get a spare set to put in two more cabinets, but haven't gotten there yet. cheers.
Nakamichi CD.
Sounds like quite a set up you have for your home system. My brother had some rare JBL pro speakers when he was going to Uni(college). He sold them years later for a profit. I think that si what got me hooked on audio. The system in my 952 is going to be pretty simple by my standards, as I used to compete in Sound Quality competition. I was actually national champion, in pro class in 2007, and have been fitting systems for31 years now.
Just FYI a single sub won't give you cleaner sound waves compared to 2 or more, it would just have less output compared to using 2 or more. Sub bass is directionless, which is why sub/sat systems in home audio work so well. our brains just assume the bass is coming from the speakers we can locate(the sats).
It can be a little different in a car, as we may have sympathetic vibrations(like a panel vibrating) that will vibrate at a higher frequency and therefore give direction cues to the sub, and we may also need to cross the sub at a higher freq, to compensate for lack of midbass from our full range speakers, which can push them into the freq range that we get directional cues from.
peace
peace
Those are nice subs. I have mostly vintage stuff and have no desire to get anything new. Car audio is pretty sorry sounding anyway, too accurate to say the least.
I have a couple of ADS 7" subs, of which I only use one, Nakamichi PA 500II amp. Nak sp seperates/ADS 320I w/ADS class A 50 amp. Good enough for me. Car audio is very intrusive and heavy in a Porsche - a quality set of full range components in the door is plenty.
Team Owner
that's the weakness of my sysetem. not enough bass from about 100~180 hz. but i have plenty of room in my sat amps to locate one more set of midbass drivers. it's just a matter of "where" to locate them in the car. i'm also reluctant to do it because of weight.
i'm thinking cross over the behind the seats speakers witch i believe are 6.5" midbass speakers at an even higher cutoff, like say, 120 hz instead of where they are now (i think they're at 100 hz now), and install 8" midbass drivers somewhere to deal specifically with making about 90 to 140 hz.
my system gets very loud now, but i think that adding two stout midbass drivers would be insane.
In my competition system, I built small boxes in front of the seats that housed 8 inch midbass drivers. These had speakers angled at the windscreen. now most of the competitors here, have copied this set up, as it helps with getting bass up front but also can improve sound staging.
As you are just trying to add midbass punch, you can get away with very small boxes. This improves power handling and helps with getting a solid kick. A lot of ppl dismissed my design till they heard it. Anyway its an option and will work better than fitting them in doors or behind seats. Midbass has a directional component so placement will effect how well they blend in.
will post some pics if i can dig them up
peace
peace
