Dropping trans to get to leaky gas tank, what else should i do?
So I'm going to be dropping the transaxle in search of a leak that happens when the car is filled up. Im expecting a crack in the tank per a thread at pelican. However, i'm wondering what else i should be looking at replacing while i have it out.
Any thoughts?
The clutch has crossed my mind (it chatters after a day of auto-x), also I am getting new tranny mounts. Anyone use the fancy blue aluminum/rubber ones from pelican?
Any thoughts?
Dumps out the passenger side on an incline (nose high or tail high), it was super full (after a 15gal fill up). It may be the filler neck but either way i need to drop the tank and see whats up.
Proprietoristicly Refined
Replace all vacuum/gas hoses on top of tank. Get new clamps--non perforated screw type or fuel injection clamps.
Be careful of the plastic fuel vent receptor on top of the tank. If you have the tank repairded, make sure the plastic and hoses can still be positioned in the tank groove.
Get some Permatex black rubber sealer for the gas tank fill tube cover to seal out vapors. Use the rest on your tail lights to keep out moisture.
Repack the 4--yes, all 4 CV joints.
It is a good time to change the fuel filter--&--Tank to fuel pump hose---&---THE BIG ONE---the fuel tank screen filter in the tank. ($45-$50). You have to remove it to get the tank fixed anyway.
Do not strip the TT torque tube to transaxle coupler bolts. Get an expensive metric hex.
GL
John
GL
John
Its still good, i just dunno when it was done. I was looking at the clarks write up and your quite right. Much more work, so i think im going to let it be for now and concentrate on the rear of the car.
