Reuse a brand new head gasket?
I'm sorry if this is a dumb question. I'm broke right now, and this little project of a head gasket job on my mom's 944 has gotten out of hand in cost. I cleaned the block deck very well. I got the head resurfaced, full valve job, and new seals and guides. I got the head back and installed it with a new head gasket. I torqued it to the second step, 37ft lbs.
Long story short, I realized I have to take the head off again. What's the word on reusing this same head gasket? Perhaps I can use some copper head gasket spray on it when reusing it?
I could buy a new HG, and probably will for peace of mind, but I wanted to see what people think. I'd love to save the cash.
I have done this on NA cars previously, but would not on a turbo car. I too like the idea of using some copper spray (the Mopar stuff they use on the SRT4's is top notch and they swear by it)
Wow, OK then, I will reuse it. I'll definitely use copper spray. Will run-of-the-mill Permatex stuff work, or should I really go out of my way to find this Mopar stuff?
Thankfully this is an NA. Not that I'd WANT to do the job over again, but it was pretty straightforward. Thanks for the input guys.
I think the risk is in the crush of the aluminum ring at each cylinder. Thats already been crushed. Some engine builders will torque a head(and other components) in stages with a time interval. Meaning they will torque the first stage then wait...say a couple of hours, then the next stage, etc. Point being that the stressed induced from the bolts will homogenise and you'll get a more accurate application. Others may torque everything down, then loosen it and retorque it.
I'm not sure this pertains to your situation, but I would just be very deliberate upon the torquing sequence, allowing things to settle between the different stages.
I am NOT so sure that any chemicals will defy the physics taking place and be of any real benefit. Don't be liberal with rtv/adhesives as this will only make a mess...you certainly do not want RTV clogging the oil galley supplying the head with oil. I would'nt use anything myself.
