Steering shaft U joint replacement.
Old 12-06-2011, 06:20 PM
  #31
Dean924s
Dean924s's Avatar
I have had a really hard time finding a suitable U joint. The cost of ones that have the correct spline count are almost as much as if you purchase a new unit. But I am still looking.
Old 12-07-2011, 11:19 AM
  #32
86 951 Driver
86 951 Driver's Avatar
Originally Posted by mikey_audiogeek
Last year. Send them an email (Jeff Clark). I'll see if I can find the invoice.
It was P/N 945.347.027.00 (Right hand drive). $85.91
Cheers,
Mike
Can these be used on the USA models or not?
Old 12-07-2011, 12:14 PM
  #33
V2Rocket
Rainman
V2Rocket's Avatar
I would definitely keep looking at VW stuff, specifically the generation of Jetta around 1980...I have a 1980 Jetta steering wheel in my car, so that end of the spline shaft worked.
IIRC the steering column of a 924/944 is taken from a Golf or something, and as I said before the splines of the 924 and 944 are the same size and count.
Old 12-07-2011, 12:30 PM
  #34
xschop
xschop's Avatar
The Borgeson joints are a perfect fit, especially on the V8 install where the engine mount set-back plate can interfere with the factory square U-joint. The DD end makes removal a breeze as well. You just need 3/4" rod machined to the DD fitment....
I confirmed with a few hybriders that the MANUAL shaft is 9.25" between the factory U-joints.....
Old 12-07-2011, 12:54 PM
  #35
V2Rocket
Rainman
V2Rocket's Avatar
a bit pricey but good to know...got a part number for the one that fits the 944
Old 12-07-2011, 01:00 PM
  #36
xschop
xschop's Avatar
Same ones Arthropraxis posted.... they are 11/16"-40
I made mine from stainless but you can do 4140 steel as it is ALOT easier to machine....
http://www.jegs.com/i/Borgeson/153/0...oductId=755261
BTW I will be working an a GM 60* V6 bellhousing adapter over the holiday
Old 12-08-2011, 04:42 AM
  #37
jfmitchell44
jfmitchell44's Avatar
Default re cheap steering shaft..
good morning gentlemen, well it is here in england. i have just purchased a replacement from my local opc for £70 plus tax. ordering from here might be an option even with shipping on top. let me know if you need any contact details.
Old 12-08-2011, 09:39 AM
  #38
Dean924s
Dean924s's Avatar
Not bad that is about $110 US??
Old 12-08-2011, 01:45 PM
  #39
V2Rocket
Rainman
V2Rocket's Avatar
too bad there's no 60* V6 worth a damn before the current 3.6L...
Old 12-08-2011, 04:56 PM
  #40
Dean924s
Dean924s's Avatar
Think Supercharged V6 from the Buick's I have always wanted to do one of those especially since they do not require an inter cooler.
Old 12-08-2011, 08:26 PM
  #41
mikey_audiogeek
mikey_audiogeek's Avatar
No.
Old 12-08-2011, 09:29 PM
  #42
V2Rocket
Rainman
V2Rocket's Avatar
I want to do one of those as well, but that's a 90* motor, not 60. Though I suppose it probably uses the 60* bolt pattern.
Old 02-20-2012, 09:52 AM
  #43
944OlderThanMe
3rd Gear
944OlderThanMe's Avatar
Hello this my first post on this forum, but I have been reading a lot about replacing the intermediate power steering shaft on my 1984 944. xschop, have you had a chance to drive the car with the Borgeson shaft that you built? I am considering building the same one in steel but I was wondering if there might be any binding in the shaft because the joints were not phased the same as the ones on the OEM shafts. If you have had a chance to drive the car with it please let me know about your experience and any difficulties you had with building it.
Thanks, Hugh
Old 02-20-2012, 12:12 PM
  #44
xschop
xschop's Avatar
1000's of miles on mine in the un-clocked position. Mine is extended over an inch as my X-member is dropped 1.25"
For the V8 swap kit I make, I extend the shaft only 1/2" but the X-member is spaced down 3/4" exactly. The angles dictate the shaft dimensions, but the Borgeson joints are adjustable with setscrews....love 'em. I clock them 10 degrees just like the factory....
Old 02-20-2012, 12:47 PM
  #45
86 951 Driver
xschop. About how much does it run to make and sell a steering shaft like that? Cheaper than the porsche part?
Quick Reply: Steering shaft U joint replacement.
