strut brace which one?
I have looked and found 2 different styles/models of strut brace's, one is an adjustable round bar the other is the Race Dynamics, there is about a $100 difference in price, what are, if any benefits of one over the other?
Personally, I like the racing dynamics one more than the usual one - because it doesn't have a pivot at both ends. With the pivots, what to stop the whole front end from shifting like a parallelogram?
I've heard the lower chassis braces like this one: http://www.rsbarn.com/968chassisbrace.htmlhelp more than the upper strut tower ones. But it requires that you get an alignment. Just something to look into.
Rainman
what would you suggest for a rear brace and where? seems to me with the trunk floor between the wheels and the torsion beam there wouldnt be much give, although ive wondered about a beam between the upper shock bolts being effective in any way
Weltmeister makes a rear harness bar/chassis brace, so does BK. The BK bar has 4 mounting points vs 2 on the weltmeister bar. These do little to stiffen the chassis, but do help none the less. next step would be a roll cage.
I'd also recomend upgraded sway bars before adding braces. My 968 Coupe has a Design 1 Lower Chassis Brace, Weltmester Rear Chassis/Harness Brace, Design 1 Strut Brace, M030 Front Sway bar, & LR 5-Way Adjustable Rear Sway Bar.
I have the KLA brace. I have heard folks grumble at the swivel joints (heim?) at the ends.....I will say that it gave the car a more firm, planted feeling on the track.
